hard start problems
Old Jul 7, 2005 | 05:01 PM
blazingchimp's Avatar
hard start problems
This just started happening and I am not sure why. If my car has been sitting for awhile (couple of hours) it has trouble starting. The engine will crank and start and rev to 1000rpm and then drop to around 200. At this point it will either catch and start or it will die. Sometimes it revs to 200 back to 1000 back to 200 and then either dies or starts. If my car isn't sitting for that long it starts fine. If its sitting for like only an hour or so the rpms only dip to about 500 instead of 200. I did some searching and it seems that most people had problems with the ECTS but those were cold starts. I just tried starting in 100 degree weather and had the same problem. I doubt its TB cuz I just cleaned that but I could be IACV of PCV. What do you guys think?
Old Jul 7, 2005 | 05:40 PM
bklynzsleepy's Avatar
keep me updated on that. my problem is that it just takes a long time to crank. sometimes it requires me to step on the gas to crank.
Old Jul 7, 2005 | 05:42 PM
killerVQ30DE's Avatar
It could still be ECTS.. i had similar symptoms and its a cheap & easy part to replace (just in radiator hose).
It does some weird calculation to workout if the temp is right (via ECTS).
If the ECTS is broken then it will give problems starting hot or cold, as its getting a wrong or out of range reading from the ECTS when it checks engine temp on startup..
mine did they same revs dropping and raising, stalling etc
Old Jul 7, 2005 | 05:57 PM
cool thanks for the feedback Ill try changing it then. I was under the impression that was a cold start problem.
Old Jul 7, 2005 | 06:52 PM
Yup mine did this business too
You crank it, nothing... crank again.. nothing.. do it again and it fires up.. hitting the gas some times helped.
After I replaced the ECTS the non-starting hasn't happened since.
Old Jul 7, 2005 | 06:56 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
2 things come to mind.
1)fuel pump/filter clogged
2)bad TPS
Old Jul 7, 2005 | 07:11 PM
Nick7455's Avatar
When I had a similar porblem I took out my starter and regreased it and it fixed the hard starting....the problem was the same in that it happened when sitting a few hours or when cold.
Old May 20, 2007 | 04:22 PM
justlikemoe's Avatar
hard start
I have the same problem with starting, I have to give it gas for it to turn, once in a while it will start. ECTS was mentioned what is it? and where is it located? I have a 2003 Maxima SE V6. I am just about to hit 29K so could be a fuel filter replacement on the way?
One more problem, when I place it in reverse, there is noise coming from the front end, sounds like the trans? any ideas? Only in reverse...How about a transmition service? I just got this car 3 months ago, with only 23K, it still smells new. Thanks new guy justlikemoe
Old May 20, 2007 | 07:55 PM
shyheim07's Avatar
2)bad TPS
I second that. I had the same problem. Changed my fuel filter, no more hard crank, comes right on
Old May 21, 2007 | 07:47 AM
hiren_patel_83's Avatar
I had the same problem, just replace your ignition switch. After that it worked just fine. Starts up in one try no problems at all.
Old May 21, 2007 | 07:48 AM
Oh yes and the fuel filter helps too.
02PearlSE
Oct 7, 2015 02:12 AM
Tha'-Max
Aug 30, 2015 01:14 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
