Odd idle
Old Feb 8, 2022 | 07:04 PM
maximanut2001's Avatar
Odd idle
After doing the rear valve cover gasket, upper intake gaskets, and the throttle body gasket replacement, I am getting an occasional odd idle condition.
When coming to a stop, the car doesn't want to idle back down to normal. Instead, it wants to stay around 1700-2100 rpms. If I turn off the car and immediately restart, the idle goes back to normal. This doesn't occur at every stop. Random really.
Old Feb 9, 2022 | 09:02 AM
LA02MAX's Avatar
what kind of gaskets did you use? Sounds like a small leak.
Old Feb 9, 2022 | 10:35 AM
Gasket set was Fel-Pro.
Old Feb 9, 2022 | 11:57 AM
CRBWS6's Avatar
Wonder if replacing the TB gasket somehow messed with the idle and an a re-learn procedure is needed? I had a tough time getting the idle to come back down to spec after a TB cleaning. Ended up doing the fuel injector unplug trick during the re-learn.
Old Feb 9, 2022 | 12:05 PM
My other readings indicate possible Idle Air Control Valve (IACV) is failing or needs cleaned. I found some videos on that.
What's the re-learn procedure look like for a 2001 Maxima?
Old Feb 11, 2022 | 11:04 AM
CRBWS6's Avatar
I think you can delete my comment. I don't think the drive by wire throttle body started until the 5.5 gen (2002-2003).
Old Feb 11, 2022 | 12:37 PM
I found this for the Idle Relearn Procedure for a 2001 Maxima. https://www.nissanhelp.com/diy/maxim...e_learning.php
Will try it out.
2kmaxima
Dec 17, 2023 02:31 AM
caseymaxima
Apr 18, 2008 06:52 AM
Majestic
Jun 6, 2007 09:03 PM
LIMaxin
Apr 10, 2004 07:15 AM
