03 Maxima SE spark plug question
Old Mar 10, 2022 | 01:13 AM
Ethane03's Avatar
Hi everyone, I drive an 03 maxima with 143 k miles. Owned it since 73k miles.
I’ve noticed the engine idling a bit rougher in the past few months and doing some research and it seems like the spark plugs may be the issue. 3 spark plugs are much more accessible. 3 require removing the intake manifold and potentially replacing the intake gasket - which is something I’m not sure I’m up for. Any thoughts on just replacing the more accessible 3 spark plugs and seeing if that helps the engine run smoother?
also are these suitable out of box?
https://www.ngk.com/ngk-6240-plfr5a-11-laser-platinum-spark-plug
thanks for any feedback!
Old Mar 10, 2022 | 12:13 PM
5thgendriver's Avatar
https://www.ngk.com/ngk-6240-plfr5a-...num-spark-plug
I would bite the bullet and replace all 6. The 3 thats easy to get to is more than likely the only ones thats been changed for the same reason you mentioned.
Good luck with her!
Old Mar 11, 2022 | 07:31 AM
Prophecy99's Avatar
yea do it all at once, and def stick with platinum NGK, the owners manual may even recommend that.
Old Mar 11, 2022 | 09:10 AM
LA02MAX's Avatar
Get yourself a small socket set and a pair of pliers, and removing the intake manifold is not bad... Worst part is two bolts for a bracket on the back side of the IM. I've left them out with no adverse affects for 200k+ miles, so the hard part is over once those are out. But definitely replace all 6 spark plugs. Or pay someone to do it.
maxs4life
Jun 25, 2009 04:23 PM
Keviwe
Feb 9, 2005 07:20 PM
TitaniumSE_MAX
Mar 13, 2003 02:10 PM
