Is a tap necessary for aluminum
Old May 20, 2022 | 11:35 AM
2002SEMT's Avatar
I am installing the (in)famous Mitzone aluminum valve covers. I removed the improper sheet metal screws and intend to buy the correct M4 x 07 machine screws. Is retapping the threads necessary or because it's aluminum, will the new screws themselves correct the thread damage from the improper sheet metal screws?
Old May 20, 2022 | 11:51 AM
RA030726's Avatar
I'm nutty for Nissans
Use a thread chaser if you can find one.
Old Jul 24, 2022 | 02:34 AM
mabsarer22's Avatar
Do you have to tap? If you threadmilled you would go through less tools since you can
Old Jul 28, 2022 | 08:49 AM
2002SEMT's Avatar
Originally Posted by mabsarer22
Do you have to tap? If you threadmilled you would go through less tools since you can just comp it out further as the tool wears Also curious, what kind of part you working on that has that many holes?
I WAS going to get aluminum valve covers. Since the screws that hold the ignition coil seal plate are questionable, I was going to modify it. After careful consideration, I decided to replace the warped plastic valve covers with OEM.
RaptonX
Feb 2, 2014 05:24 PM
pimpin02max
120
Aug 19, 2007 08:55 PM
Maximeyez
Feb 4, 2004 05:26 AM
kpark
Feb 7, 2002 09:40 PM
