Aftermarket radiators
Old Sep 29, 2022 | 08:16 PM
NZ 4th gen cefiro's Avatar
I just purchased a radiator for my 5th gen maxima (NZ maxima, same as i30) but when it arrived today I noticed the core is only 16mm thick (the original radiator core is 26mm) surely this is not acceptable as a replacement?
Does anyone have any experience with these aftermarket radiators? there is no way I'm putting this in my car if it is going to cause overheating. The transmission cooler pipes don't line up either, one will need a longer length of tube to fit, the current radiator in my car only has 70mm between the trans cooler lines.
Any advice would be much appreciated
Old Sep 30, 2022 | 10:44 AM
RA030726's Avatar
I'm nutty for Nissans
What's the part number?
Old Sep 30, 2022 | 10:48 AM
RA030726's Avatar
A quick check on Rockauto shows all are 16mm thick.
Old Sep 30, 2022 | 12:44 PM
uptownsamcv's Avatar
I'm running a Denso unit that I got from Rockauto and never had any issues.
Old Oct 2, 2022 | 04:57 AM
16mm thick is a 40% reduction in core volume compared to stock, I can't see how that is a good thing. It probably doesn't equate to a 40% reduction in cooling if the frontal area is the same, but i can't see how it would be the same cooling as the 26mm stock core.
Old Oct 2, 2022 | 10:45 AM
RA030726's Avatar
If there was an issue then they wouldn't be available. The rad on my 99 is thinner than other 4th gens. It's stock. It's a non issue.
Old Oct 2, 2022 | 07:59 PM
User1's Avatar
Stack two of them up. Should be good then.
eastsidemoon
Jun 23, 2016 09:01 PM
ffcbairn
Feb 11, 2013 04:01 AM
pinakbet
Jun 4, 2007 02:15 PM
mjf3232
Mar 9, 2006 06:26 PM
surfer
Oct 3, 2004 08:03 AM
