5.7 swap alternator question
Old Nov 10, 2022 | 09:07 AM
uptownsamcv's Avatar
I ended up picking up a 2014 engine with 102,000 miles for a little under $1,200. free shipping and no core charge, only issue is that it came from a wrecked car and the front valve cover was cracked . the fuel rail is also bent where the fuel line connects, I guess someone had a hard time getting it off than decided to remove it at the firewall.
I was wondering if I can use the 150 amp 8th gen alternator (2019 and newer) if I change the alternator pulley to a 5th gen pulley? my 2014 engine came with it's upper alternator bracket intact. I put this 95 alternator that I have laying around on to the block just to see how much off the bracket hole is. I have the Nisformance kit on the way. I have a used G37 150 amp alternator on the way that I found for $40 shipped that I am going to test fit also.
I plan to return the Duralast Gold alternator that I have on the car now, so far I have had 3 incidents with alternator pulleys coming off...
Old Nov 10, 2022 | 08:09 PM
Child_uv_KoRn's Avatar
Bad *** Newb
As long as the belt lines up. Pulley can't come off with permanent thread lock and an impact.
Old Nov 11, 2022 | 07:20 AM
now I need to get this crank pulley bolt off.
I don't know why they put them on so tight from the factory. 150 ft lbs is the most I ever torque them to and they never come off.
Old Nov 11, 2022 | 11:58 AM
Bad *** Newb
They didn't. It's the rust. You'd be surprised how much force rust can hold on that little lip from bolt to pulley.
Big boy 1/2" impact time. Also, soaking it in penetrating oil works. Couldn't impact (back in the day with lower power stuff) or starter bump one before, but I let it soak overnight and it spun off no problem the next day.
Old Nov 11, 2022 | 01:47 PM
cool, i sprayed it down and I'll spray some more before I leave to work tonight.
I've had this kobalt electric impact for a quite a while, hopefully it does the trick..
Old Nov 12, 2022 | 11:14 AM
I got it off.
I jammed a 3/8 extension into the crank pulley and was able to jam it on a part of the oil pan (the 7th gen oil pan that won't be needed for the swap) than hit it with a breaker bar and long pipe...
any tips on alternator pulley removal?
Matt_01SE_20th
Nov 29, 2007 08:12 AM
GOST
May 5, 2004 08:15 AM
gotamax91
Feb 17, 2003 06:43 PM
