Replacement window switch won't work
Old Jan 5, 2023 | 01:27 PM
2002SEMT's Avatar
My old master window switch won't control the passenger side window. I tried a couple from a salvage yard then bought a reman from switch doctor. Only the old switch bank will work (minus passenger window functionality). Any attempt to replace yields no functionality whatsoever. What might be the problem?
Old Jan 6, 2023 | 06:32 PM
fd3rew's Avatar
does your passenger window side switch work? you need a fully functional passenger side window switch for the master window switch to work. When the passenger side switch is in its home position (not press or pulled) it connects the circuit from the master switch to the passenger side window motor. You can probably pull a rear window switch and put it in the passenger side that's not working to test everything out.
Old Jan 6, 2023 | 07:02 PM
2002SEMT's Avatar
If I reach over to the passenger switch, it works. The replacement master switch has no functionality at all on any window.
knight_yyz
Oct 15, 2007 04:57 PM
philzaga
Jun 16, 2005 06:45 PM
ojman
Oct 17, 2004 09:30 AM
dennisuello
Oct 13, 2004 01:00 PM
miT
Jun 20, 2004 05:53 AM
