P0011 p0430 340 codes at once
Old Mar 12, 2023 | 07:13 PM
maxinout93's Avatar
Og member here i just got my 03 I35 from the shop 2 days ago. It sat maybe 4 months or so, i would drive it maybe once a month or so because of a massive leak on front valve cover, didnt want to risk blowing the motor or a fire. So the 430 code haa been on a while, i thought it was due to oil dripping on the converter, but leak is fixed now. So went to get car from shop n battery was dead, n drove it a mile 2 autozone and shut it off where battery died again. Jumped it off it drove and ran like a new car and idled very smooth. Now today whenever im parked or stopped, the car acts like it wants to shut off and shakes real bad. While im driving there is no shaking or any signs that the engine wants to shut off, it runs great while driving. So today i get p0011, 430. Ect so i thought it might be the ivt control on the front bank near radiator, i swapped it with a spare i had, and idle was still ruff, so i pulled a coil #2 and it had oil on the boot, so i swapped it. Still idles rough. Only other thing i can think of is spark plug, which they are copper plugs. Problem is only at idle.
Old Mar 12, 2023 | 07:40 PM
chrome91's Avatar
Whats the voltage at your battery when its idling? If it's not charging, the ECU can cause funky issues because of lack of power, something is up with the battery dying unless its a plain bad battery. If the oil leak was bad, oil could have leaked onto the alternator and caused it to fail which could have caused everything. When its idling toss a voltmeter on the battery terminals, if its not between 13.3-14.5 area something is up
Old Mar 13, 2023 | 05:17 PM
Reality sucks's Avatar
What does the data Say... how are you getting these codes ??
Old Mar 13, 2023 | 08:37 PM
Child_uv_KoRn's Avatar
Bad *** Newb
IVT solenoid is dirty
Old Mar 14, 2023 | 04:13 PM
maxinout93's Avatar
I changed the battery, and dont have a voltmeter, but will try and get 1. The Alternator did devolop sort of a whine noise a while back i guess because the oil was leaking onto it.
Old Mar 14, 2023 | 05:38 PM
maxinout93's Avatar
I have a code reader anytime the check engine light comes on
Old Mar 14, 2023 | 05:40 PM
maxinout93's Avatar
I have a spare and will try to clean it, but what if the code comes back? That is the code for bank 2 radiator side?
Old Mar 28, 2023 | 03:16 AM
maxinout93's Avatar
I guess i should ask which side does the p0011 correspond to bank 1 radiator side or bank 2 firewall side? If i have that correct. Ive replaced and cleaned the ivt solenoid radiator side and code still pops up.
Old Mar 28, 2023 | 07:57 PM
Bad *** Newb
rear bank
Old Mar 28, 2023 | 07:59 PM
Bank 1 Is the Rear. (Fire wall)
Bank 2 is the Front. (Radiator)
When you had ivt out did you check the Solenoid electronically for operation..? To verify it infact works. You should be able to test this part on and off the car.
Old Mar 28, 2023 | 08:09 PM
Bad *** Newb
Yep, and split it apart to clean properly.
And if it's clean and works...the gaskets..... O_O
Old Mar 29, 2023 | 05:22 PM
maxinout93's Avatar
rear bank
Man thanks alot! Ive been messing with and cleaning the wrong 1 lol. I thought the code was for the ivt near the radiator side lol. Well that explains why whenever I clean that one, the code still comes up lol.
Old Mar 29, 2023 | 05:24 PM
maxinout93's Avatar
I didnt bother to check it, what do i need to check it? like some small jumper wire or something? Would harbor freight have something similar?
Old Mar 29, 2023 | 08:03 PM
Bad *** Newb
I just used car battery with jumper, iirc.
Old Mar 31, 2023 | 05:43 PM
maxinout93's Avatar
Well guys that was indeed the problem!! The ivt solenoid on the rear bank was dirty. I was gonna swap it with a spare that i had, but i realized its the same part but on the rear of the motor the ivt on that side has the plug on a different angle than the ivt on the radiator side, so it would be impossible to use. But that solved my rough idle problem. I removed it and sprayed it with parts cleaner and reinstalled everything. Fired her up and to my surprise, no more shaking and no more than codes so far, and no more rough idle.
PopularWithVertigo
Jul 25, 2021 09:38 AM
moldyearwax
Apr 25, 2021 04:12 PM
JoshG
85
Jun 19, 2016 04:16 PM
nissandrvr98
Jan 6, 2015 07:52 PM
norcallump
May 22, 2011 12:12 PM
