first issue after 7th gen swap
so far I put a little over 150 miles since swapping in the 2014 engine and I think I'm hearing a noise from the power steering pump. I'm starting to wonder if I over tightened the power steering belt. I just tightened the belt as much as it would go...
any opinions??
any opinions??
Definitely not the right way to tension the belts. Look at the FSM process here. It's always a guestimate when I install them because I don't have a way of measuring the force applied to the belt, but it's nowhere near as tight as it can go. There needs to be some deflection. If I ever do the 7th gen swap, I'll try to retain their accessories - the single belt design with an auto tensioner is just so much better.
https://www.nicoclub.com/service-man...F2002%2FMA.pdf
I wanted to use 7th gen accessories but I just put in a brand new compressor last summer and A/C lines. I didn't want to have to buy another compressor, P.S. pump and alternator as well as make custom A/C lines.
when I get my new pump I'll make sure the belt isn't tightened as far as the tensioner will go.
Maximeltman
18
May 4, 2018 05:02 PM
maxinout93
20
Mar 25, 2014 10:36 AM
