How to fix a check engine light that does not work?
Old May 21, 2024 | 10:03 AM
nick's Avatar
The light does not light up when I turn the ignition on my 2001 SE AE 5 speed. The previous owner said that the cluster was not altered.
I'd like to get it fixed for future CA smog testing. Could this be a bulb that has burned out? What else should I check?
Old May 21, 2024 | 12:10 PM
TallTom's Avatar
Start with the bulb since it's the cheapest and easiest test.
Old May 21, 2024 | 01:22 PM
nick's Avatar
That's my plan, did some searching and it seems that the early 5th gens that were made between 1999-2000 have bulbs while the later 2001-2003's have LED's that are soldered in.
I'm just curious to know if there could be anything else besides the bulb on the cluster and pins/wires at the ECU that could have been altered to prevent it from illuminating.
Old May 22, 2024 | 07:08 AM
Prophecy99's Avatar
does the light matter for inspection? doesn't inspection test scan though OBD-II anyway?
(yes it would be nice for the light to work for sure , not saying that, but for inspection you can maybe get by and play dumb?)
Old May 22, 2024 | 10:37 AM
Here in CA, the CEL light must be operational in order to pass, regardless of the year of the vehicle.
Old May 22, 2024 | 10:43 AM
nick's Avatar
I'm pretty sure that it does for CA smog inspection, unless the technician performing the smog check skips/forgets to verify that MIL does illuminate when the key is in the ignition and goes right into connecting the OBD2 test equipment to verify that the emission monitors are set.
Old May 22, 2024 | 12:52 PM
flames101sully's Avatar
If the bulbs around it are still working then it's most probably the bulb burnt out
Old May 23, 2024 | 07:01 AM
Prophecy99's Avatar
good to know, prolly same in south eastern PA
Old Jun 26, 2024 | 01:44 PM
nick's Avatar
Issue fixed; it was one of cluster bulbs.
Old Jun 27, 2024 | 06:51 AM
Prophecy99's Avatar
great!
shodog
Feb 16, 2017 01:38 PM
pwittenb
Aug 10, 2016 09:47 AM
demonics12
May 22, 2011 08:48 PM
brandnew
Mar 20, 2011 12:06 PM
Qmax03
Oct 30, 2004 07:20 AM
