2002 Maxima hard stuttering/stalling when off high idle
Old Mar 6, 2026 | 01:11 PM
Depresment's Avatar
Hey all, I recently bought a somewhat low miles 2002 maxima from an elderly couple and have been doing maintenance that they missed. Car drove 221 miles home just fine, but after I changed the spark plugs, cam sensors, crank sensor, and downstream o2 sensors it developed an intermittent 'misfire on cylinder 6' and 'random intermittent misfire' that would go away on its own. Recently I parked it for around 2 weeks and when I tried to start it again the car would run off high idle perfectly but the second it lowered to normal idle it would start stuttering really bad and end up stalling, the fuel pump stays running until it's stalled and the filter is new.
Is there anything I should try or any next steps?
File Type: avi
Old Mar 6, 2026 | 01:25 PM
slvr2KSE5's Avatar
put the old sensors back in for starters
Old Mar 6, 2026 | 02:47 PM
Depresment's Avatar
The reason I replaced them originally was the o2 sensor not functioning and the cam/crank sensors seeming to cause a no start/random stall condition
Old Apr 28, 2026 | 03:50 PM
IanChavez's Avatar
Kuulostaa siltä, että autossa on nyt joko sytytys- tai polttoainejärjestelmän epätasapaino. Koska ongelma alkoi spark plugien ja roosterbet.app antureiden vaihdon jälkeen, kannattaa tarkistaa ensin sytytysjärjestelmän kytkennät ja maadoitukset, erityisesti sylinterissä 6. Myös kampiakselin ja nokka-akselin anturien kytkennät voivat aiheuttaa epävakautta. Tarkista polttoaineen paine myös tyhjäkäynnillä – vaikka polttoainepumppu käy, paine voi pudota liian nopeasti. OBD2-lukija voi antaa tarkempia vikakoodeja, jotka auttavat rajaamaan ongelmaa.
maxinout93
Jan 28, 2015 12:32 AM
komodo693
Mar 16, 2011 09:46 PM
Nevermore
Apr 9, 2009 10:27 PM
Dave Holmes
44
Feb 12, 2009 07:44 PM
Xugg
Aug 21, 2004 04:48 PM
