Stuck Accelerator Pedal!!!
Hey all, just so you know, be careful if your car is outside and cold... I left a parking lot and got on a main road, the car was like 3/4 warmed up (according to temp gauge), and i went WOT. The next thing i knew, the pedal stuck full down!
I tried to get my foot under it, but no luck. I then hit the brakes, and was just about to pop it into neutral when the pedal came back out. WHEW! A few mins later, i went to WOT again to test it, no problem, like normal... must have been the pedal lubrication freezing or somethin. Oh well, look out all...
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
Re: Stuck Accelerator Pedal!!!
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
See what you should do is go to your local Infiniti dealer, and complain about the stuck pedal, and If they can't duplicate the problem make them give you a new 2002 I35. I hear Infiniti has the best costumer service so I'm sure they will help you out..
Report It
Since the stuck pedal is a safety issue and design flaw you should report it to the NHTSA. If enough people report it, they will force Nissan to issue a recall and a fix.
http://www.nhtsa.dot.gov/cars/problems/ivoq/default.htm
Roger
As I recall,
there are others reporting this.. I've seen two other reports of this, and I believe it was a max and it was cold out. I wish I could remember where I read that.. maybe I dreamt it :/
I had my throttle stick when I put my cai on. A clamp was in the way when going wot. Jamed the pedal past it and it wouldn't come back. Scared the **** out of me. Simple adjustment to the clamp fixed it but it does catch you by surprise.
tarun900
19
12-20-2021 06:57 PM
RealityCheck
10-02-2015 06:34 PM
HerpDerp1919
09-29-2015 02:02 PM
