When to change spake plugs on Supercharged Maxima??
Old Feb 16, 2002 | 04:23 PM
DMan_2KMax's Avatar
Hey guys its been a while since I've posted. My max has been running great now for a whole year with absolutely no problems!! Just curious about yalls opinion on when to change the platinum spark plugs on a force induction (i.e. turbo or SCed) engine such as mine. My shop suggested doing it every 30K with turbo and supercharged cars. What do yall think? Thanks
Diederik
Old Feb 16, 2002 | 04:53 PM
Sly's Avatar
Sly
Re: When to change spake plugs on Supercharged Maxima??
Diederik
I think you should check the condition of your plugs much more often when running forced induction, or NOS, but not necessarily replace them. Pull one out and look at it. If it looks OK then put it back. If it looks bad then replace them. How often you check depends on how confident you are in the platinums holding up to the abuse, but every 20-30K miles is probably reasonable.
Old Feb 17, 2002 | 12:50 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I would change mine every 30K. Make sure you use one step colder plugs.
Old Feb 17, 2002 | 11:10 AM
DMan_2KMax's Avatar
Why would you want to use one step colder plugs? Wasn't Stillen's V2 SCer kit designed to run with the stock spark plugs? Will changing the plugs to one step colder decrease my gas mileage? What type of plugs are you running in your max Kev?
Old Feb 17, 2002 | 11:18 AM
Sly's Avatar
Sly
Using one step colder plugs shouldn't affect fuel economy. It's just an extra safety measure to prevent pre-ignition.
Old Feb 17, 2002 | 11:50 AM
Y2KevSE's Avatar
As Sly said, "It's just an extra safety measure to prevent pre-ignition." Since you live in Texas, weather gets really hot during the summer, increasing the chance of pre-det.
I'm running 2 step colder plugs. You shoul use this part number from Nissan (one step colder) PFR6B-11 (stock plugs are PFR5B-11)
Old Feb 17, 2002 | 10:06 PM
Adboy's Avatar
Dman,
I think you should race me again.
Y-pipe is in... UDP soon... waddya say? You can even get new spark plugs if you want!
Good hearing from you again,
Travis
Balkins
Aug 12, 2015 06:39 AM
Flores94
Aug 11, 2015 12:53 PM
rhonster
Aug 6, 2015 05:46 PM
RealityCheck
Aug 5, 2015 06:18 AM
maxima297
Aug 3, 2015 12:50 PM
