Wierd clutch issue? Clutch diagnosis needed
Old Feb 26, 2002 | 06:41 AM
Colonel's Avatar
Old Fuddy Duddy
OK, this is really starting to drive me nuts. When the car has been sitting for a while, not necessarily cold, under a load (around 3k) there is a stuttering/hesitation. I thought at first it was maybe a motor issue
After further looking/driving, I think it might be a clutch issue. The clutch is getting grabbier in all bands and gears. I used to be able to smooth it in w/o issue. Now its making me look like I have no clue how to drive a manual. Once the car warms up (about 5 minutes or so) the problem, other than the grabbiness, goes away? Am I looking in the correct area?
Question: How is the best way to test if the clutch is starting to fail or has issues? Best way to prove to customer service..ha ha.
Stats:
2K1, 5spd SE
128000 Miles
NO performance mods -- I have Franken but cannot put in until this is resolved
I have slightly wider tires/rims
Old Feb 26, 2002 | 07:48 AM
craaaazzy's Avatar
Re: Wierd clutch issue? Clutch diagnosis needed
Stats:
2K1, 5spd SE
128000 Miles
damn, 128k miles on a 2k1?
mmmm...while driving, put it in a higher gear and floor it, if ur tach goes up and ur not accelerating, then clutch problem.
Old Feb 26, 2002 | 08:01 AM
got rice?'s Avatar
seems like pressure plate issues
Old Feb 26, 2002 | 08:03 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Stats:
2K1, 5spd SE
128000 Miles
Colonel,
Just a guess, but I believe it's just that the manual trans fluid is not up to temp yet. It's viscosity hasn't "thinned out" yet, since it hasn't reached normal operating temps. Mine does this too. That's what I attributed it to or the ECU adding in the extra RPMs to warm the cats up faster causes my shift timing to be off.
If this is the case it should be worse the colder it is outside, since it takes longer to warm up. I plan on installing the Redline MT-90 I bought a long time ago one of these days and I'm pretty sure it will help, since it's viscosity is thinner in colder temps.
P.S: I probably don't need your stock shift boot anymore, so if you still want a custom one, just send it in.
Old Feb 26, 2002 | 08:04 AM
Colonel's Avatar
Old Fuddy Duddy
Stats:
2K1, 5spd SE
128000 Miles
Ummm, thanks for the typo check...that would be 12,800..sheesh I am fat fingered....ugg.
As for pressure plate issues...how to postively verify?
Alex...sorry man, just not organized enough...I apologize...I still have not sent in my money for the other stuff yet either...HAVE to do that today...man I will be so happy when this wedding stuff is finished...
Old Feb 26, 2002 | 08:14 AM
IceY2K1's Avatar
Re: Re: Wierd clutch issue? Clutch diagnosis needed
Jon,
I wasn't giving you grief. It's just that I'm switching the complete console bezel(shifter surround/boot/chrome ring) from a 2K2, so I don't need a 2K1 boot anymore. Hopefully, it fits.
Old Feb 26, 2002 | 10:39 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: Wierd clutch issue? Clutch diagnosis needed
Originally posted by IceY2K1
Jon,
Non taken..best o'luck to that 2K2 fitting. Whats the draw, does it look a lot better?
Old Feb 26, 2002 | 11:16 AM
IceY2K1's Avatar
Re: Re: Re: Re: Wierd clutch issue? Clutch diagnosis needed
You tell me.
Also, the leather seems to appear more like real leather than the plastic looking 2K-2K1 also, but that's just a bonus.
I just like the chrome ring and I think it will set off my AE shift ****, plus it hasn't been done before so I'm just curious if it fits.
Old Feb 26, 2002 | 11:44 AM
CIRCO's Avatar
Stats:
2K1, 5spd SE
128000 Miles
The stuttering or hesitation could be the TSB for manual transmissions. The best way to test your clutch is to put it in first let the clutch out till it grabs, then put it in second till it grabs, and the same for 3rd, 4th. See if the car dies in any gear or it should pull a little getting gradually less in the higher gears. If it dies you could have a bad clutch, but I highly doubt it at 12K unless you were burning out at every single stop light or stop sign.
Old Feb 26, 2002 | 03:08 PM
MS 2K1 AE's Avatar
Stats:
2K1, 5spd SE
128000 Miles
This is an old test, but it seems to be pretty accurate. I don't know exactly what part of the system it diagnoses (clutch, pressure plates, release, etc), but the method is as follows:
Park your car in a wide open lot (not in front of a wall or curb!)leave the car running at idle...pull the emergency brake all the way up...engage the clutch...put the tranny in 5th...disengage the clutch quickly. This will obviously cause the car to stall. However, you need to pay attention to how the car stalls. If it dies quickly, the clutch is fine. However, if it sputters and chugs and takes a few seconds to die, the clutch needs replaced.
This sounds wierd, but the test has proven to work every time for me (I've gone through a few clutches over the past 15 years).
Good luck!
Old Feb 26, 2002 | 03:45 PM
Colonel's Avatar
Old Fuddy Duddy
Thanks for the info
seems like I should be testing to see how it dies in the higher gear range. I will test that tomorrow.
Alex...looks good. Let me know how it turns out...you wont just be the only one if it does...he he he...
How do you plan to deal with the plastic "pull" up ring for what I think is for engaging reverse?
Old Feb 26, 2002 | 03:56 PM
IceY2K1's Avatar
Re: Thanks for the info
...How do you plan to deal with the plastic "pull" up ring for what I think is for engaging reverse?
Whatchu talk'n bout Willis!
Old Feb 26, 2002 | 07:32 PM
Y2KMaxGXE-R's Avatar
I have similar prob since day 1 I have my car. over the time I've learned to smooth it out, but sometimes its just uncontrollable. The way it is going, I think I'll need new motor mounts pretty soon. Well, this is my 1st Max, and it is a stick. I had Nissan mechanic testdrive it, he said that the car has so much power that it is ok for it to jerk that way. BTW he drove it the same way I did, if not worse, so I am a good shifter.
My car is at 24K mi young, and the wtty is 60K mi, I'll wait and see what happens. No lights are lit on the dash, so it has nothing to do with fuel-cut TSB, per my dealer.
Lakersallday24
Jun 16, 2019 01:35 AM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
carlosvq30
Aug 17, 2015 11:32 AM
maxima-junky
Aug 13, 2015 09:59 AM
