Noise at startup, '02
My '02 GLE makes a noise at cold start sometime which sounds like it might be the timing chain rubbing against its housing. Anyone have a similar experience or hear of this problem?
Trey
'02 GLE
Merlot/Tan
Trey
'02 GLE
Merlot/Tan
try...
startup with the Climate Control on "OFF" or "ECON", we seem to be having alot of noise coming from the A/C clutch.
if it still makes it, then yes it is probably your timing chain. I understand they made some changes to quiet the chain on the 3.5L, so I wouldnt really have any input there (3.0L here).
Re: Re: try...
Originally posted by Igal
check your oil level. when was the last time you changed your oil?
Let us know when you find the cause.
I'll try the 'climate control off' solution, but the noise doesn't show itself every morning, so I don't know if that will tell me anything.
Sounds like the starter is not disengaging from the flywheel. Problem could be the ignition switch or the starter. Next few times you cold start it, consciously turn the key back from the start position as soon as you hear the engine catch. If there is no noise, then the key switch return spring is not breaking the connection to the starter motor quickly enough.
But it is more likely that the problem is in the starter - most likely a sticking solenoid. Get it fixed before you damage the teeth on the flywheel. Replacing a flywheel is an expensive job.
Good luck.
Good luck.
I've noticed the same with my '02 GLE, but it is inconsistent. It has happened maybe 8 times since taking delivery in October. Always happens on cold start, regardless of how far driven immediately before. I have 3K miles and two oil changes.
I think I'll try shutting off climate control when I park to see if it is the a/c compressor. Since it is inconsistent, I may have to do this for a while.
Answer
just spoke with a service advisor with one of the local dealerships. This guy owns an 02 Max and has experienced the same problem. He has spoken with the technical team in California about it. The noise is indeed the timing chain striking the upper metal chain guide as the tensioner (which is oil pressurized) starts to take up the slack. He tells me that it does not cause damage and that Nissan is familiar with the sound. The clatter occurs b/c 1. there is no oil in the top ½ of the timing chain assembly at cold start, and 2. the tensioner is oil pressure driven. Thus, as soon as the oil pressure rises (which is immediate after the engine starts), the upper ½ of the timing chain gets lubrication and the tensioner has taken out any slack.
I'm not thrilled with the answer b/c I really think that will lead to premature chain wear/failure, but at least I now know what is causing the problem.
Re: Answer
