Hayden 404 Tranny Cooler / Permacool Tranny Cooler
Old Mar 6, 2002 | 09:23 PM
nissanmaximas's Avatar
Hey org!
Anyone had experiences with either one of these tranny coolers? also what are the goin rates for these coolers? any feedback is appreciated.
Old Mar 6, 2002 | 09:50 PM
Dario's Avatar
i have the permacool, choose it over the hayden due to the fins inside the cooler that rotate the oil. going for $65.00 shipped
Old Mar 6, 2002 | 09:55 PM
BigDogJonx's Avatar
Damn a tranny oil cooler for only $65??? Damn, that is a cheap investment for saving yourself from Tranny repair later.
Dario, was this hard to install? 1hr? 2hr job?
I would love to do this just for increased safety and pulling strain off the tranny.
Dixit
Old Mar 6, 2002 | 09:59 PM
Dario's Avatar
not too sure i had it installed took them about an hour or less.
if your interested BigDogJonx let me know and i can get you one for $65 and get a group deal going for 7 or more and its $55 shipped to you
Old Mar 6, 2002 | 10:09 PM
BigDogJonx's Avatar
Now we talking partner. Last question, how thick is it? and what the dimensions? The hoses and everything come with it?
Dixit
Old Mar 6, 2002 | 10:12 PM
Dario's Avatar
ill get you that info tommorrow, ill PM you with all the info
the tranny cooler can withstand up too 250 HP, thats the application that i went with.
But if you want you can go higher ill get back to you
this is from there website
Why Perma-Cool® Performs Better
In an ordinary oil cooler, the oil flows straight through tubing without interruption. The oil nearest the wall of the tubing becomes "cool" and sluggish, while the oil near the center remains "hot" and thin. The cooler outer layer of oil serves as an insulation for the inner hotter oil and the thin, freely flowing oil at the center passes through the coil without the full advantage of heat exchange with the tubing. Simply stated, ordinary coolers are designed to get in their own way.
Perma-Cool® coolers incorporate the patented TurbulatorTM fins to "mix" the hotter and cooler oil with oversize tubing to insure ample oil flow. The result is a design that takes full advantage of heat exhange with the coil and prevents stalling of the oil flow while providing more of a temperature drop. This difference is important and it's only available from Perma-Cool®.
Old Mar 6, 2002 | 10:20 PM
BigDogJonx's Avatar
You still aint give me the sizing info and wheather or not it comes with the hoses and all the required materials?
Old Mar 6, 2002 | 10:30 PM
Dario's Avatar
ill give you the exact info tommorrow can you PM me your email??
Old Mar 6, 2002 | 10:39 PM
BigDogJonx's Avatar
dsuthar@comcast.net
Dixit
Old Mar 6, 2002 | 10:40 PM
Dario's Avatar
thanks
Old Mar 7, 2002 | 05:53 AM
srbarnes4ever's Avatar
I'd be very interested if the group deal goes through. I'm still a wee bit concerned about cold weather driving with a tranny cooler as I'm not positive that the tranny fluid would get warm enough for optimum operation. Can someone give their thoughts on that? Other than that, the pluses far outweigh any negatives I can think of. Just wish there was some kind of bypass ( ala a thermostat) that would not send the fluid to the external cooler until a certain temp was reached....My email is srbarnes@lexmark.com; thanks in advance Dario.
Old Mar 7, 2002 | 06:53 AM
Dario's Avatar
ill check into that for you this afternoon
Old Mar 7, 2002 | 10:18 AM
Dario's Avatar
detail on bypass valve
temp below 180 and 90% of fluid is bypassed only letting 10% through to the cooler to prevent air pockets
temp above 180 and the valve will fully open and bypass 95% of the fluid through the cooler
Prices
Solo
Cooler $65
Bypass Valve $66
Group (7 or more on each)
Cooler $55
Bypass Valve $59
PM me if interested
Old Mar 7, 2002 | 02:20 PM
Prices
Solo
Cooler $65
Bypass Valve $66
Cooler $55
Bypass Valve $59
PM me if interested
Thanks for the update Dario! I'm definitely interested; hopefully we have enough folks here to pull off a group deal! Keep me posted!
Old Mar 7, 2002 | 02:40 PM
Dario's Avatar
glad to hear your interested now we just need 6 more on the cooler.
Anybody else????
Old Mar 7, 2002 | 03:51 PM
im down lemme know when and where and how.
Old Mar 7, 2002 | 04:11 PM
Anybody else????
so thats the cooler for 55 and the valve thing for 59 and it comes with all the necessary hardware and manuals, shipped, correct?
Old Mar 7, 2002 | 06:22 PM
Dario's Avatar
thats correct
Old Mar 7, 2002 | 07:23 PM
melteye's Avatar
I might be interested in purchasing as well, if I had a SC and Nitro later will I have any problems with this cooler?
Also, what warranties will be voided when installing?
Old Mar 7, 2002 | 09:10 PM
Dario's Avatar
well this application is only good for 250 hp once you get SC and NOS u may want to consider the a step higher which would be good until 450hp as far as voiding any warranties you may void ur tranny, u may want to ask ur dealer before u decide
Old Mar 7, 2002 | 10:18 PM
ima just hold down the cooler and valve. i just got a new tranny from Queens Nissan, thier tech messed my first tranny up, so they had to order me a new one haha haha jerks, i was beefing with them the whole time, they had no choice but to take my sh*t and my dads sh*t!
Old Mar 8, 2002 | 05:27 AM
Deac's Avatar
Hmmmm...
Prices
Solo
Cooler $65
Bypass Valve $66
Cooler $55
Bypass Valve $59
PM me if interested
Isnt this mod only for Automatics?
Old Mar 8, 2002 | 06:10 AM
Dario's Avatar
thats a good question, but dont the 5 speeds have a tranny cooler i would suppose they do
Old Mar 8, 2002 | 06:13 AM
Dario's Avatar
alright whoever is interested PM me so i can make the list
nissanmaximas and srbarnes4ever i already have u both down for both the cooler and valve let me know if this is correct
Old Mar 8, 2002 | 07:42 AM
yes it is SIR!
Old Mar 8, 2002 | 07:29 PM
Dario's Avatar
Originally posted by yo_its_ok
No 5spd tranny has ATF that needs cooling...unless you want a gear oil cooler
yes sir u are right, but did you know that you could use this cooler for engine oil as well, my dealer told you could use them for both engine oil or tranny oil, and if any 2k2(auto) are interested let me know, same application.
the 2k2 can use the 250 app engine/tranny oil cooler for the tranny due to the fact that tranny oil will never get as hot as engine oil.
Old Mar 9, 2002 | 07:17 AM
Yep I'm still interested Dario so keep me informed if we get enough for group deal pricing. I hadn't realized this could also be used as an oil cooler. I do want to check into warranty risks should this be installed though, I don't want my warranty voided with all of the slipping automagics out there.
Old Mar 9, 2002 | 08:37 AM
Dario's Avatar
alright guys so far 3 coolers and 2 valves, anybody else interested in an oil/tranny cooler???? 55 shipped for cooler and 59 for valve on group deal, lets try to get this going
Old Mar 9, 2002 | 09:57 AM
Dario's Avatar
ill check into that, thanks for the input yo_its_ok
Old Mar 9, 2002 | 05:59 PM
Where is the oil leaving and entering the engine ?
There is no external source like a AT w/ a factory cooler.
Need an adapter, and if its more than 1" thick your filter is dangerously close to your control arm, and even if the adapter plate is there, the hoses run very close to the accessory belts.
Dario, do some research about oil coolers, and you'll understand what I mean.
But it can be used to cool the tranny though, without causing the problems you speak of right? what your talkin about is when you use it for the engine oil?
Old Mar 9, 2002 | 08:47 PM
Dario's Avatar
yeah he is talking on engine oil, the tranny cooler i have currently and have never had any problems at all
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
