Clicking noise on startup?
Old Mar 13, 2002 | 12:33 PM
theMax's Avatar
When I turn the key but do not start the car, I hear clicking noises comming from under the hood. (you might have to open the hood or get outside the car to hear)
Is this normal? What is it?
Old Mar 13, 2002 | 06:03 PM
silentbuzz's Avatar
hav eu just installed a intake kit?
Old Mar 13, 2002 | 09:25 PM
theMax's Avatar
I've had my CAI a few months now and this is when I first noticed it. I thought it was the ecu relearning or something but it happens every time.
Next time you start your car, listed...am I the only one?
Old Mar 13, 2002 | 09:59 PM
00Semaxi's Avatar
That clicking noise could be your motor mounts, I heard that same noise under the hood of my max, took it to the dealership and they replaced them. I never heard the sound again.
Old Mar 13, 2002 | 10:05 PM
MaxedOut2g's Avatar
i think i get the clicking sound...should i be worried about it? if so, gonna need help taking intake out dammnit and putting it back in
atw
Old Mar 13, 2002 | 10:39 PM
ABS's Avatar
ABS
Re: Clicking noise on startup?
Sounds like the relay for the starter motor. If you turn your key, but the car doesn't start, but you hear clicking, then your battery is probably dead.
Old Mar 13, 2002 | 10:43 PM
Larrio's Avatar
The Definitive AE Master
it happens to mine also, i'm not all too worried about it. I'm pretty sure it only happens to automatic trannies cause we probably got something turning in there
Old Mar 14, 2002 | 12:10 AM
bernie2000se's Avatar
it just started on mine as well, motor mounts hmmm thats interesting, I hope that's not the case, but if it is thats why we still have warranties
Old Mar 14, 2002 | 10:34 AM
augie's Avatar
I get the same thing as well. When you start it and turn it off, you hear like a clicking sound. Anybody have the same thing turning it off? If its not normal then I will take it my service dept right away.
Old Mar 14, 2002 | 10:57 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It's normal...
There are relays that switch on/off to control fluid dampening to the motor mounts.
Not sure what they did to make his stop clicking, besides disconnect the relays which can't be good.
Old Mar 14, 2002 | 11:47 AM
silentbuzz's Avatar
It could be the solenoid adjusting to the incrase in air. Mine went away after driving for a bit.
Old Mar 14, 2002 | 12:06 PM
njmaxseltd's Avatar
Possibly the idle air control valve. It's a stepping motor which clicks as it moves.
Old Mar 14, 2002 | 12:14 PM
dm7297's Avatar
mine does it too when i shut my car off it makes the clicking noise too mines a 5 speed so i dont have the liquid filled motor mounts so i doubt its that
Old Mar 14, 2002 | 12:22 PM
IceY2K1's Avatar
You don't.
I have a 5-speed and I was told by a Nissan tech it was the motor mounts.
Old Mar 15, 2002 | 05:42 AM
dm7297's Avatar
Re: ...
Originally posted by IceY2K1
You don't.
it might be the motor mounts but its not the liquid filled thing they were talking about cuz on a 5 speed there not liquid filled you can even look in the fuse pannel that fuse is not plugged in
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
