Adco Rear Sway Bar
Old Mar 14, 2002 | 03:09 PM
Burton069's Avatar
Adco Rear Sway Bar
I put the Bar in about a month ago, but now I notice how on every little bump it sounds like it is hitting something. Is this common? or is the sway bar loose?
Old Mar 14, 2002 | 08:20 PM
Bob_Jaap
Addco rear Sway Bar
I just installed my Addco rear sway bar last week and have also noticed it sounds like something is hitting the ground on certain bumps on my normal route. I haven't had time to investigate it yet. Perhaps the U-bolts on the axle are too long.
Old Mar 14, 2002 | 08:24 PM
Versace's Avatar
There are alot of threads on this topic, search. You will have to side the U bolts all the way to the edge (where the bar bends) or move them in a little further. I reccomend moving them to the outer edges as far as they will go. This makes the car corner the flattest. It takes about 15 minutes with a ratchet set, just slide under the car and do it.
Old Mar 14, 2002 | 09:30 PM
WizzaMax's Avatar
Both complaints are on a 2k or higher car, do this...check the bracket only on the right side in the back. I bet you will find scores on the back parts of the flat bracket where the lowest portion of the right rear suspension just behind the rear crossmember sits...if you move it in towards the center about 3-4 inches you will miss the lowest part of the beam and the sound will go bye-bye. Best of luck and Happy Maxxing!
Old Mar 14, 2002 | 09:39 PM
ItalianMax2kSE's Avatar
Re: Adco Rear Sway Bar
How do I join P.A.C.T?
I want in ASAP!
-Joe
Old Mar 14, 2002 | 10:35 PM
bernie2000se's Avatar
Wizzamax, knows what he is talking about, because he fixed mine doing what he just wrote about, he is the man for sway bars.
thanks,,, Tracy
Old Mar 15, 2002 | 07:57 AM
Bob_Jaap
Thank you! I will take a look and follow your advice.
Bob
Old Mar 15, 2002 | 08:34 AM
max34's Avatar
Which bracket? The "U" bracket, or the small rectangular bracket.
I noticed some noise coming from my exhaust banging on a support beam. I guess my hangars have weakened.
Old Mar 15, 2002 | 10:22 AM
WizzaMax's Avatar
The U bolt fits over the rear crossmember and plugs into the flat bracket which sandwiches onto the lateral bushing bracket...the trailing edge of that it what most likely is contacting the rear sosp...
Old Mar 15, 2002 | 10:48 AM
max34's Avatar
Rear SOSP?...
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
