Speedo/Guage Problem
Old Mar 20, 2002 | 07:34 AM
KilrBz's Avatar
Anybody have problems with the guages going out? I'm having a problem where all the guages (speedo, tach, odo, fuel, temp) go out at the same time. Usually the guages with needles will get stuck in a set position and the odo becomes illegible. Only happens once the car is warmed up, usually after more than 20 minutes of driving.
The car is an '01 SE 5 speed with 18,600 miles. It's at the dealer today, but I'm not confident that they'll find anything so I'd apprecaite any help. Thanks. Dan
Old Mar 20, 2002 | 08:42 AM
djmaxski's Avatar
Hopefully it's just a loose connection or something...
Old Mar 20, 2002 | 08:48 AM
jjs's Avatar
jjs
If the whole cluster is going out...
I would say probably a loose or poorly fitting wiring harness somewhere in the line....
Old Mar 21, 2002 | 05:33 AM
KilrBz's Avatar
I wanted to let everyone know that they found a faulty circuit board on my car that was causing the guage cluster problems. I don't know which circuit board. They ordered a new one under warranty and it will be installed next week.
The important thing to note is that they said this is the second one they've seen with this problem. Could be another thing to add to the list of 5th Gen issues.
Old Mar 21, 2002 | 07:16 AM
Dario's Avatar
the circuit they are talking about is mounted directly behind the gauge faces, make sure they recalibrate the miles(odometer) to the correct setting since i was told it holds the mileage
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
