Nearing 30K miles and needs Major Service
Old Mar 22, 2002 | 10:53 PM
MaximaTrojan's Avatar
My 2K max is nearing 30K miles. I got this $284.88 coupon for Major Service that's due at 30K miles. What do u folks think? I'm thinking about taking it in tmrw.
Old Mar 22, 2002 | 11:29 PM
serin's Avatar
Re: Nearing 30K miles and needs Major Service
i don't think you need to do that since i believe our cars have timing chains so no belts to tension (so my mechanic tells me). take that money and get your fluids flushed instead. i just finished having all mine done: coolant, oil, brake, power steering, and tranny. that's flushed not just changed. other than that, i don't know what else there is to do for maintenance.
Old Mar 23, 2002 | 12:30 AM
the paragon's Avatar
I'm planning to take my car for 30K service soon. tell me how it goes.
Old Mar 23, 2002 | 01:23 AM
HyperBlack's Avatar
I've got over 40,000 miles on my 2000 SE (manual). No problems so far and never took it in for a check-up. Just had a transmission fluid flush at 34K. However my right tail light just went out. WTF is up with that?
Old Mar 23, 2002 | 01:35 AM
Re: Re: Nearing 30K miles and needs Major Service
lighbulb loose? or needs replacment perhaps
Old Mar 23, 2002 | 01:55 AM
HyperBlack's Avatar
Don't know yet, going to see tomorrow. All ready bought the bulbs, but just the fact that it's only been 2 years that p!$$in' me off. Oh yeah, and one other thing, the bottom of my driver's side heated seat isn't working. Anybody have a similar problem or fix? It shouldn't be a big deal since spring is here, but I live in Wisconsin, AKA: the frozen tundra, so I've kinda become dependent on them.
Old Mar 23, 2002 | 05:36 AM
jnm2kse's Avatar
I've seen lots of Maximas with a tailight out...I thought it was normal although mine are still burning strong at 44k
Old Mar 23, 2002 | 07:20 AM
GXEme's Avatar
I'm guessing they go a little early because of the way the lights are setup. I don't know about you but when my car is running my lights are usually on. Anyway, one of mine went at around 30,000 miles and the other followed shortly after. If you feel like it replace both at the same time. I think the bulbs usually come in 2 packs.
Old Mar 23, 2002 | 07:28 AM
GXEme's Avatar
Oh, and I just went past my 60,000 mile mark on my 2k GXE. I had the radiator and tranny flushed, oil and spark plugs changed and tires rotated. I did the plugs myself, they cost over $12 a piece (NGK Platinum tipped).
Old Mar 23, 2002 | 07:36 AM
Max2000's Avatar
that's what I paid when I got my 30,000 miles service done.. they flush almost all the fluids and roated tires and etc.... I was taking a long trip so that's why I had it done.. but nothing was wrong with the car.. they wanted to do an injector flush(trying to get more money out of me..) but I didn't go for it...
Old Mar 23, 2002 | 07:58 AM
Y2KMaxGXE-R's Avatar
they wanted to do injector cleaning at 7500 and 15000..but I told them to step off. My 30K service will be due sometime this summer, and I do not intend to do more than just brake adjustment, oil/filter change, etc per manual. I dont view it feasible to change fluids at 30K because I paid 20 grand for the damn car.
Old Mar 23, 2002 | 09:36 AM
Fluid Flushing?
check out the fluids first b4 taking it in for service. if the coolant is bright green, no need a coolant flush. if your oil is not super black, don't need an engine flush. if your trans fluid is still red, don't need a trans flush. injector flushes are totally a waste of time and money.
i plan on taking it in for the 30K servce just to keep my baby in tip-top shape. and for proof that i actually maintained the car so it's value will supposedly be more if i decide to sell it.
Old Mar 23, 2002 | 11:38 AM
Re: Fluid Flushing?
come to think of it, the difference if you have all your receipts and car maintained at a dealer vs. NOT is a couple hundred dollars..
Old Mar 24, 2002 | 10:35 AM
BuddyWh
Re: Fluid Flushing?
Have to disagree... you should flush and change the coolant every two years to replace the anti-corrosion package, even if the coolant is bright green. Unless you have changed over to Dexcool, which lasts 5 years or more.
Also true of auto transmission flush... flushing gets the fluid out of the torque convertor and cooler, otherwise you'll only drain maybe 1/2 the fluid. Very good idea at 30k.
I do agree about engine flush and injector flushes, though. They are only necessary if the car has been poorly maintained or has problems, not as a routine service item.
BuddyWh
Old Mar 24, 2002 | 03:16 PM
Blackgums100's Avatar
May I recommend
switching to Redline synthetic tranny fluid at 30K. Check the how to section for a very easy replacement or just have your local shop do it. It is a nice investment, especially for those of us that are hard on our trannies.
markevans999
Oct 25, 2015 08:27 AM
minsbang
Sep 11, 2015 08:48 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
