rsb install help
Old Mar 27, 2002 | 05:15 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
rsb install help
i got my addco the other day and went to install today and had instructions in hand. everything went smoothly until i could not for the life of me to get the bolt to through the bushings and mounting plate on the trailing arms. i went with the ramps approach, mainly because i had them on hand. i tried using a mallet, hell, i even used a c clamp to bring it together and it just wasnt happening. do i need to file anything or should i go get some larger square U bolts with the same threads or what? any tips that arent listed on the typical install sheets? i will give it go tomorrow if i can figure out another approach. i greatly appreciate any input.
Old Mar 27, 2002 | 05:23 PM
NuJerseyDrive's Avatar
Re: rsb install help
What the hell is wrong with those people @Addco Time and time again they keep sending people the wrong U-bolt for the trailer arms. Sloppy, I went throught the same thing. Got my bar through a group buy and the majority of us (5th Gens) received U bolts that were too small. Do not even bother with the instal until they send you the right one. Give them a call, they shouldn't have a problem recognizing their mistake since they've dikked over so many of us already.
Old Mar 27, 2002 | 05:29 PM
sloppymax's Avatar
thats a relief. i thought i was a total idiot. i got mine from greg, but i guess i can contact addco anyways to see if i can get a larger u bolt. do you have any contact numbers or email for someone at addco?
Old Mar 27, 2002 | 05:35 PM
Sorry but I don't have their # anymore. Try to ask Gregg, he should have their customer service #.
Old Mar 27, 2002 | 05:57 PM
sloppymax's Avatar
ok, i just dropped greg an email. thanks for the heads up NuJerseyDrive.
Old Mar 27, 2002 | 06:34 PM
Anytime...
Good luck with the install.
Old Mar 27, 2002 | 08:15 PM
LeftCoast's Avatar
I installed my addco RSB this past weekend...I had the same problem UNTIL I realized there are TWO types of mounting plates. One of the varities of plates has a larger hole. Use "larger hole" plates for the square bolts...
-Left
Old Mar 27, 2002 | 09:03 PM
makeHerPurr's Avatar
ADDCO contact info: (800) 621-8916 sales
or
www.addco.net
Also check out the lousy hardware that I received...
http://www.sweetcar.org/maximaRSB/DSC00009.JPG
On a good note, ADDCO is very responsive and will ship out new HW ASAP.
Excalibur23
Oct 13, 2015 04:33 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
