Car lowered with springs. Want it lower.
I just had my car lowered with H&R springs. I want it to be about an inch lower. It is on a 01 max se. I have stock struts and shocks. I am looking for it to be adjustable. I see people using a combination of shocks and struts. I just need to know what compnaies make what. If you reply to this please don't use abreviations for the parts, I am a newbie and don't know what it means.
Re: Car lowered with springs. Want it lower.
How long have you had it installed? Wait for a week for it to settle before deciding on anything.
As for using struts/shocks that won't help lower it. That's what springs are for. Struts/shocks are to dampen the bumps, compression and what nots.
KYB (AGX, they're adjustable), KONI and Tokico's seems to be the most common manufacturers for Max struts.
atw
One and the same. Ground Control is the brand
Originally posted by Y2KMaxGXE-R
can someone explain in more detail...the difference between coilovers and ground controls? Everything I may need to know..
Dixit
I have a 2001 SE with stock struts. Anyways, the front still seems high, but the back is nice. Its been almost 2 weeks for me, so I havnt seen drastic differnce sinc ethe day it was installed. It has dropped a bit more and the ride has soften a bit. Regardless, to the untrained eye, they will not know your car is lower.
guys you're scaring me to death. One guy here put Eibachs on and has more wind noise. Ppl have alignment problems. Mods are scary.
TRUE coilovers, like Cattmans' $1600+ Gen-II coilovers, include KYB AGX struts and are height adjustable. They also come with camber/caster adjustable over-tower mounts. The over tower mounts allow you to drop ~3/4"-1" more without losing ANY wheel travel, plus look DAMN sweet in RAW unpainted billet. They also use "pillow *****" to keep the turning radius and "helper springs" to prevent noises while going over bumps.
The Cattman coilovers are worth EVERY penny they cost. However, not too many of us can throw down that kind of cash.
Originally posted by IceY2K1
Ground Controls are just springs with adjustable perches(mounts) that you can turn up/down to change ride heights, but require additional shocks/struts.TRUE coilovers, like Cattmans' $1600+ Gen-II coilovers, include KYB AGX struts and are height adjustable. They also come with camber/caster adjustable over-tower mounts. The over tower mounts allow you to drop ~3/4"-1" more without losing ANY wheel travel, plus look DAMN sweet in RAW unpainted billet. They also use "pillow *****" to keep the turning radius and "helper springs" to prevent noises while going over bumps. The Cattman coilovers are worth EVERY penny they cost. However, not too many of us can throw down that kind of cash.
My 2c.
Not a fair assessment. For 1/3 that price you can get a shock/spring combo which will ride the same as an SE (if not just slightly stiffer), offer a totally better overall driving experience, safer on hard turns, lower center of gravity and less rocking F-R-F during hard acceleration and braking. Not to mention the fun factor you gain that's just priceless.
Even w/o doing the mods your stock suspension will give you problems now or down the line - and mis-alignments can happen in either case. That's the nature of anything material.
comes out, if I cant flash with 1500 cash, I better not mess with my stock suspension....since springs mess up the alignment, and cause harsher ride, other potential problems...
Re: Re: Car lowered with springs. Want it lower.
c'mon now
Wind noise = It's a common thing, i don't see any relevance as to why lowering would cause it.
Alignment problems = A common thing anywhere you go. Hit a big pothole doing 70mph and you're sure to get one - whether it be on stock or aftermarket suspensions. You'll probably mess up your wheel while at it as well.
Mods are scary = Seriously? What's scary is when you take a 50mph on-ramp and your car feels like it's going to fly off. I'm a firm believer of what a good suspension can do to your car and how it rides.
Speaking of scary mods, get rid of your entire sound system. Play it loud enough and you'll lose your hearing far earlier in life
Real coilovers, come as an asembly already put together fit for your car. Cattmans are very nice, one small prob that will prob be fixed in the next gen and i'm guessing will be able to be added to the existing. All in all nice. 1600-1800 is normal for real coilovers. These are very nice because the shock (agx) is adjustable for firmness/softness, so you can adjust it as you need it for different situations. Plus they have no bump stops to give you hard bumps. They have raised mounts instead that give more shock travel.
Also you may want to look into air bags.
Would Cattman's coilovers reduce the harshness otherwise experienced by having coilovers in the first place? (Given it has AGX's)
Had a little chat with Y2kev a while back and he recommended against getting the Coilovers in my case primarily because i live in Houston where we have a smorgasboard of potholes and uneven roads.
He mentioned something about the ride getting too harsh as opposed to just a plain shock/spring combo like H&R/AGX.
What specific harsness' are you refering too? I can tell you that even on full firm(which you don't need) they still ride real nice, stiff but good. Overall they are very smooth, take bumps well, corner and handling ability is night and day.
Why do you have to get aftermarket shocks if you get aftermarket springs? What are the consequences if you don't? Are there any other adjustments or changes you should make when installing H&R springs? I was under the impression that you could just switch out the stock springs with the H&R's and keep right on drivin'...
so who knows if it's still good
)- Trunksu
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
NOT YOU TOO???
