Hood fix!! $20.00 and literally 5 minutes....
Old Apr 8, 2002 | 07:04 AM
jjs's Avatar
jjs
Thanks to those in the attached thread (and Dave B.)!!!
http://forums.maxima.org/showthread....4&pagenumber=2
Install took five minutes (most of which was letting the cleaner dry from wiping the lens top where the 'packs' adhere)!
Took her up to 95 and no flutter!
Old Apr 8, 2002 | 07:07 AM
BigDogJonx's Avatar
Re: Hood fix!! $20.00 and literally 5 minutes....
What does this hood fix do?
Dixit
Old Apr 8, 2002 | 07:12 AM
soundmike's Avatar
Very sound, Mike
Re: Re: Hood fix!! $20.00 and literally 5 minutes....
Fixes the problem with the hood fluttering experienced by some owners.
Dixit
Old Apr 8, 2002 | 07:14 AM
jjs's Avatar
jjs
Takes care of that 'flutter' most of us have seen...
in the sheet metal...
While travelling at highway speeds (and higher), if you look at the surface of the hood right in front of the driver, most have a visible 'vibration'...
Old Apr 8, 2002 | 07:23 AM
soundmike's Avatar
Very sound, Mike
Interesting to note that i never experienced this. Must be the Carflector's dynamics pushing the hood down
Old Apr 8, 2002 | 07:42 AM
jjs's Avatar
jjs
Could very well be...
or maybe if there are 'lips' to the Carflector that curve around the edge of the hood in the same place as the 'lamp packs' they pretty much fill the void themselves...
Old Apr 8, 2002 | 07:43 AM
Bulldawg's Avatar
Who is Dave B? and how do I get in touch with him to get the parts.
Also where do I get the instructions to fix it.
Old Apr 8, 2002 | 07:52 AM
jjs's Avatar
jjs
Check out the thread I referenced for some....
part info and instructions...
As for Dave...
Dave Burnette 512-225-7424 (Austin, TX)
Old Apr 8, 2002 | 08:01 AM
soundmike's Avatar
Very sound, Mike
Actually, there are "lips". I just fixed it then ... also for $20 (off ebay).
Bulldawg, check out stickies for a link to the TSB (w/ illustrations)
Old Apr 8, 2002 | 09:55 AM
LeftlLane's Avatar
yes I have this crappy fluttering, and yes I have a hood protector. My car is still under warranty, can't I have them fix it?
Old Apr 8, 2002 | 09:59 AM
soundmike's Avatar
Very sound, Mike
You have a Carflector too?
Anyway, yep. Since there's a TSB out it should be "easier" to get your local dealership to fix the problem out of warranty.
Old Apr 8, 2002 | 10:01 AM
Bulldawg's Avatar
Don't bother trying to take it to nissan you will just waste your time. The first time I took mine in they told me that my tires were out of balance and that they balanced them and it was fixed. The second time the retard mechanic just adjusted my alignment screws so far that the hood was sticking up over the fender. I plan on buying the parts and fixing it myself because it sounds pretty easy.
Old Apr 8, 2002 | 10:03 AM
LeftlLane's Avatar
Where is this TSB? Please thanks!!!!
Old Apr 8, 2002 | 10:09 AM
soundmike's Avatar
Very sound, Mike
Technical Service Bulletin
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
