Alarm wire colors for your 2000 max..
ITEM | WIRE COLOR |POL| WIRE LOCATION |
|12V |green |+ |ignition harness |
|STARTER |black/red or blk/wht|+ |ignition harness |
|SECOND STARTER|black/blue |+ |ignition harness |
|IGNITION|black/red (smaller) |+ |ignition harness |
|ACCESSORY|red/yellow |+ |ignition harness |
|SECOND ACCESSORY|white/blue |+ |ignition arness |
|POWER LOCK|gray |- |pin 23 at SECU *1 |
|POWER UNLOCK|brown/yel |- |pin 35 at SECU *1 |
|LOCK MOTOR|purple | |pin 15 at SECU *1 |
|UNLOCK MOTOR|white/black | |pin 13 at SECU *1 |
|DISARM DEFEAT|green/yellow | |pin 14 at SECU *1 |
|PARKING LIGHTS +|red/blue | |driver kick panel *2 |
|PARKING LIGHTS -|lt. blue | |headlight switch |
|HEADLIGHTS|grn/yel(L),blu/blk(R|- |headlight switch *7 |
|DOOR TRIGGER|*3 | |SECU *1 |
|DOME SUPERVISION|use door trigger | | |
|TRUNK/HATCH PIN|purple/yellow |- |pin 38 at SECU *1 |
|HOOD PIN|yellow/red |- |pin 27 at SECU *1 |
|TRNK/HTCH RELEASE|blue |*4 |pin 12 at SECU *1 |
|FCTRY ALARM ARM|orange/black|- |pin 41 at SECU *1 |
|FCTRY ALRM DISARM|orange/blue |- |pin 30 at SECU *1 |
|TACHOMETER|white/green | |instrument cluster *5 |
|SPEED SENSE|pink/blue | |instrument cluster *6 |
|BRAKE WIRE|red/green |+ |brake switch or drivers kick|
|HORN TRIGGER|green/white |- |steering column |
|WIPERS|blue(L), blu/blk(H) |- |steering column |
|LF WINDOW UP/DN|blue - green |A |drivers window switch |
|RF WINDOW UP/DN|red/wht - red/blk |A |drivers kick panel |LR WINDOW UP/DN|yellow - red |A |drivers kick panel |RR WINDOW UP/DN|grn/wht - green |A |drivers kick panel |SUN RF OPN/CLOSE|not recommended | |
RADIO 12V|yellow |+ |at radio |
|RADIO GROUND| | | |
|RADIO SWITCH|purple |+ |at radio |
|RADIO ILLUMINATE|red/white |+ |atradio |
|POWER ANTENNA|green/white |+ |at radio |
|LF SPEAKER|blu/wht - blu/yel | |at radio or speaker |
|RF SPEAKER|brown - brn/wht | |at radio or speaker |
|LR SPEAKER|lt. grn - blk/yel | |at radio or speaker |
|RR SPEAKER|blue - pink | |at radio or speaker |
Notes:
This vehicle has an immobilizer system that needs to be bypassed during remote start operation. Use DEI part number 555U.
*1 The SECU (Smart Entrance Control Unit) is located to the passengers side of the steering column.
*2 Can also find red/green or red/yellow at fuse box.
*3 Find lt. blue for the drivers door in pin 29, red/blue for the passenger front door in pin 40, and red/white for the rear doors in pin 28. Use all 3 wires and diode isolate each.
*4 Requires a high-current ground for activation.
*5 Located on the rear of the instrument cluster in the white plug. Do not start the car with the cluster unplugged. Can also find the white/green at the ECM located in the front of the center console on the transmission hump. The wiring is easily reached by removing the panel just to the front of the center console on the passenger side. DO NOT UNPLUG THE ECM.
*6 Located on the rear of the instrument cluster in the 20 pin brown plug. Do not start the car with the cluster unplugged. Can also find the wire at the ECM.
*7 These wires are high current negative, must use relays.
|RADIO GROUND| | | |
Notes:
Now..for a disclamer...DO NOT blame me if you break....fry....disable your maxima..remmeber electricy is dangerous.always use a Electronic multimeter...NO test lights..NO analog meters...to test and verify wires and their function. If your not familiar with working with solder..wire strippers..and a volt meter..get someone to help you out...or take it to a SHOP! Please be careful...i have other cars..if you need the wire color guide..let me know.
WORKS WITH 2000, 2001 maxima's.
QueensMAX
Sep 15, 2015 04:14 AM
Shouldnt this be a sticky?
