How often do you change the air filter ?
Old Apr 15, 2002 | 06:47 AM
dougb's Avatar
I've actually started changing mine every 15k or so. I find that the car runs alot better with a fresh air filter.
Old Apr 15, 2002 | 06:57 AM
TimW's Avatar
The silent but deadly Moderator
15K
its usually pretty nasty by then..
Old Apr 15, 2002 | 07:05 AM
lcf's Avatar
lcf
who changes this usually?
Old Apr 15, 2002 | 07:15 AM
djmaxski's Avatar
Um, you can... Its definitely a DIY item!!!! Loosen the two clips on top of the airbox and pull up. Replace filter and put the tray back in and refasten the clips.
Yeah, unless you're running a K&N, Monster, Amsoil, etc, 15k is about the limit because it gets really dirty by then, and all that dirt restricts airflow and makes the car perform less than perfect.
Old Apr 15, 2002 | 07:33 AM
lcf's Avatar
lcf
word, i know this, im trying to figure out if someone has replaced it already or not. do they usually replace during oil change too? i think i remember a dood at jiffy lube telling me i needed a new one. theyre always checking all sorts of stuff trying to make more money, heh.
hm, when i was home on holiday from school it is possible my father could have gotten it replaced. even more confusing, it is possible my girlfriend might have got it done at her work (she works at a honda dealership). i'll look into this.
anyway, tell me this, where can i buy a k&n drop-in filter? is there a specific size i should keep in mind?
also, if im planning on getting an CAI soon, should i even bother with this?
Old Apr 15, 2002 | 08:31 AM
djmaxski's Avatar
If youre unsure about when the filter was changed, pull it out and see how dirty it is. I don't mean to be an a$$ about it, but if its clean then it doesn't need to be changed. Yeah, they do check usually check your filter with an oil change, but ask them to show it to you, don't just take their word. If they change it every 3000 miles for you because it's "dirty" then they make more money and you get ripped off because it should last around 15k or so.
You can order a K&N drop-in from a number of places online, or you can go to your local AutoZone and get one and save on shipping. Either way its still going to be $50 (w/o Shipping). You will need the 33-2031-2 (I think).
If you plan on getting a CAI soon, then don't even bother with the K&N because you will be removing the stock airbox and filter and then won't have any more use for the $50 filter you just bought.
97_GXE
20
Sep 17, 2015 08:12 PM
thenewguyy
Sep 12, 2015 11:12 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
sdotcarter
Sep 2, 2015 09:53 PM
