Sunlit Sand Max. with Konig Tantrums pict.
Old Apr 16, 2002 | 03:26 PM
makeHerPurr's Avatar
http://www.sweetcar.org/maxNewWheelsSmall.JPG
Please help with one question:
At low speeds of 20 mph or less, the car(steering) is affected by the road condition. The car will pull left or right with uneven roads. This was not as pronounced on my original wheels/tires. Is this normal with the wider wheels/tires (original 205/65/15, new 235/45/17)?
The wheels/tires are new. Wheels mounted with 66.1 hub ring and torqued to 80#.
Old Apr 16, 2002 | 04:24 PM
NuJerseyDrive's Avatar
What kinda tires did you get? Some tires require them to rotate a certain direction. When I mounted mine I put 2 of them going the wrong direction, this caused my car to pull to the left. Once I corrected this the pull stopped.
Old Apr 16, 2002 | 04:41 PM
Deven2kStickMax's Avatar
I had this same rims with 235/45/17 on 17X8 Tantums on my sunlit sand that crashed on 10/07/01. To get the best out of it, you need to drop your car with lowering springs, try Eibachs or something else of your choice. THIS IS MY X CAR/SUNLIT SAND TAKE A VIEW OF THE TANTRUMS
Old Apr 16, 2002 | 04:52 PM
My car is lowered.
Old Apr 16, 2002 | 05:01 PM
I was very careful to mount the tires with the correct direction of rotation. The car drives straight as an arrow on smooth and flat roads. It's only when I encounter rough roads that the car pulls to one side or the other. I know this happens, but the new setup is SO much more noticeable.
Old Apr 16, 2002 | 05:12 PM
serin's Avatar
pretty normal with lower profile tires i think. i noticed a difference just with newer tires, going from 225/50 r17 to 235/45 r17. it definitely tracks more and is more sensitive to road conditions. that's the price you pay for higher performance --> less comfy.
Old Apr 16, 2002 | 05:42 PM
Weasel's Avatar
It's normal to notice an increase in the tendency to follow imperfections in the road surface when you change to a wider tire with a high-performance tread pattern.
Old Apr 16, 2002 | 08:56 PM
NuJerseyDrive i was not refering to you. Sorry about that. I was refering to makeHerPurr, who posted a pic with his tantrums.
Old Apr 16, 2002 | 09:28 PM
Alright cool, I shoulda known better.
I know what you mean by getting the best of it. I love the improved feel of the road, what a difference!
matts95max
Apr 23, 2025 10:44 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
Pixel
Sep 15, 2015 05:53 AM
minsbang
Sep 5, 2015 05:36 AM
