tire size
Re: tire size
Originally posted by Flash2k2
so what's the proper tire size, 235/40 or 245/40, for 18" rims???
First, I'm only going to deal with four aspects of upsizing: overall wheel/tire diameter, rim width, speed rating and load rating. These are the most critical parameters in terms of safety.
1. OVERALL WHEEL/TIRE DIAMETER: You should maintain an overall wheel/tire diameter that is no more than 3% greater or less than the OEM wheel/tire diameter. Otherwise you'll incur an unacceptable speedometer error. An excellent tool for comparing overall wheel/tire diameters is located at:
http://www.miata.net/garage/tirecalc.html
The OEM wheel/tire diameter is based on a tire size of 225/50R17.
2. RIM WIDTH: The acceptable rim width ranges for various tire sizes are posted on the manufacturers' web sites. NEVER EXCEED THE MINIMUM OR MAXIMUM ACCEPTABLE RIM WIDTH FOR WHATEVER TIRE YOU SELECT. And never accept anyone's advice on what constitutes acceptable rim widths OTHER than the manufacturer's. The word "anyone" specifically includes tire DEALERS and people on this forum. Both are notorious for providing dangerous and irresponsible advice in this area. If you're interested in knowing why you should not exceed acceptable rim widths, take a look at the discussion under the topic of RIM WIDTH in the following article from Dunlop:
http://www.dunloptire.com/tiretech/?...tire_width.txt
Pay particular attention to the words, " . . . could result in failure."
3. SPEED RATING: NEVER PURCHASE A TIRE WITH A SPEED RATING LESS THAN THE SPEED RATING OF YOUR OEM TIRE. Speed ratings are designated by letter (i.e., H, V, Z, etc.) and are imprinted on the tire's sidewall. The speed rating for a 5th Gen Nissan Maxima SE with OEM 17" tires is a "V".
4. LOAD RATING: NEVER PURCHASE A TIRE WITH A LOAD RATING LESS THAN THE LOAD RATING OF THE OEM TIRE. Load ratings are designated by number (i.e, 89, 91, 93, etc.) and are imprinted on the tire's sidewall. The load rating for a 5th Gen Nissan Maxima SE with OEM 17" tires is a "93". In general, the lower the aspect ratio, the lower the load rating. (The Dunlop article referenced above underscores this point. It says, "[c]hanging tires on a vehicle from one aspect ratio to another also influences section width, which relates directly to the load carrying capacity of the tire. The load carrying capacity of the original equipment tire must always be maintained or increased.")
For a complete definition of all major tire sidewall markings and their locations, take a look here:
http://www.dunloptire.com/sidewall.html
Now that you know what to look for, here are a few questions to test your knowledge.
1) Is it OK to mount 235/45R17 tires on OEM 5th Gen Maxima SE rims? The answer is NO! The reason is that the 5th Gen SE rim is only 7" wide. The minimum acceptable rim width for 235/45R17 tires is 7.5". There are no exceptions to this regardless of the tire's make or manufacturer. Once again, check the manufacturer's web site for confirmation.
2) Is it OK to mount 235/40R18 Kumho ECSTA 712 tires with 18" X 8" rims on a 5th Gen Maxima SE? The answer is MAYBE! Why is that? Well let's break it down. The overall wheel/tire diameter only produces a 1.8% speedometer error when compared to the OEM tire size of 225/50R17, so you're OK there. The minimum acceptable rim width is 8", so you're OK there. The speed rating is a "W", so you're OK there. But the load rating is only a 91 as compared to the load rating of 93 for your OEM 17" tires. So on the surface, the tire is not acceptable for use on a 5th Gen Nissan Maxima SE. However, the standard OEM tire on the SE is a 215/55R16 with a 91 load rating. So in this case, you can probably get away with it.
So here's the final exam question. Is it OK to mount 245/40R18 Kumho ECSTA 712 tires with 18" X 8" rims on a 5th Gen Maxima SE? Do the work yourself, Flash2k2. Then let us know what you find out. (And please don't anyone else help him.) If it turns out that your answer is yes, then tell us which tire is the better fit . . . the 235/40R18 or the 245/40R18?
A final comment: NEVER PURCHASE RIMS UNTIL YOU KNOW WHAT SIZE TIRES YOU'RE GOING TO RUN ON THOSE RIMS. Make certain that the tires you select meet all of the above criteria. Then purchase rims that are wide enough to properly support those tires.
Hope that helps.
Re: Re: Re: tire size
Uhhhhh... the 245/40R18 technically is a better fit for 18x8" rims using AVS db's tire specs
Consider yourself empowered, Flash2k2. And enjoy the ride!
Re: Re: tire size
That was well written, how ever I disagree with your last statement. It should be the other way around, figure out what size wheel you want first then what tire size based.
Your car dictates what wheel size and your wheel dictates what tire size.
You are certainly right about listening to "other" people...I bought wheels and tires and they order the wrong size wheels. 18x7.5 and mounted 245s on them, minimum recommended is 8", nuts!, so I cancelled the order just as they where taking my wheels off, luckly I had 8.5 on the bill of sale.
Anyhow, now I am picking a different set of wheels, 18x8.5 with 245/40s.
Hope that helps.
Hope that helps.
So both rim width and tire size should be taken into account when arriving at a decision.
Originally posted by freeze2k2
it seems this question will never go away
knight_yyz
Nov 1, 2015 01:34 PM
