Swirl marks on the hood?!?!?
Old May 10, 2002 | 01:32 PM
2k2maxima's Avatar
Hey how's it going guyz, i just recently noticed some swirl marks on my hood - they seem like scratches but I'm not quite sure how it happened as I wash the car at home, maybe from the way my friend waxed it???!?!?!? I only see these scratches if I look at the car at a certain an angle?!?!?!? Someone pls. let me know if I can do something about it.....
Thankz in advance......
Later
P.S - NOT TO MENTION MY 2k2!!!!!!!!!!!
SOMEONE PLS. HELP....
Old May 10, 2002 | 01:37 PM
drudawg888's Avatar
yeah i got those too.. no big deal. go buy some scratch remover and rub it out.
Old May 10, 2002 | 01:57 PM
Maximus1000's Avatar
Its typically not that simple for swirl marks. If you want to do it right you'll need some specific swirl mark remover and a few hours as its tedious work. Go to www.autotopia-carport.com for more info.
Old May 10, 2002 | 01:59 PM
[maxi-overdose]'s Avatar
Re: Swirl marks on the hood?!?!?
dun wipe ur car too hard after u wash it....
best thing I have tried to remove swirl is Mcguire scratch X...just use is as polish
Later
Old May 10, 2002 | 02:15 PM
2k2maxima's Avatar
Also.
I was wondering is a towel good to use to dry the car??!?!? I've tried this but it seems to attract a lot of lint...can someone pls. let me know what kinda stuff I should use?
Thankz again....
Later
Old May 10, 2002 | 02:19 PM
PrinzII's Avatar
OG and counting...
Swirlmarks
Maximus: www.autopia-carport.com
Truthfully, there are many approaches to removing swirl marks. The most common is getting a polish such as 3M's Swirl Mark Remover or Meguiar's Swirl Mark Remover 2.0. Many people use Finesse It II or Scratch X to get rid of deeper swirls.
It also depends on how you intend to apply the product. I have swirls on my 2002 but I intend to attack those with 3M Swirl Mark Remover for Dark Colored Cars and a Porter Cable 7336 Orbital Polisher with a foam polishing pad. Some people do it by hand but it will take longer.
Old May 10, 2002 | 02:21 PM
Re: Also.
100% pure cotton stuff.....my mom digged out the washable diapers that I used 20 something years ago and those are the good stuff. if it cant hurt a baby's ****...it is not going to hurt ur maxima paint.
and yes...those diapers are cleaned!
Thankz again....
Later
Old May 10, 2002 | 02:28 PM
drudawg888's Avatar
hey works for me. my car must be atypical.
Old May 10, 2002 | 02:34 PM
MONTE 01&97 SE's Avatar
Truth is you will never be able to get them totally out, no matter how much Swirl remover you use!
Old May 10, 2002 | 02:41 PM
2k2maxima's Avatar
The only problem is that it's a little too visible......I have a Gray Lustre car, so the thing shows up even more....what would you suggest would be the best product for me to use???? And do you know if i'd be able to buy this at places like pepboyz and stuff?
Thankz for all your help in advance....
Later...
Old May 10, 2002 | 03:27 PM
acMAX's Avatar
My friend (a bimmer owner with no swirl marks) told me that a lot of swirl marks come from when you apply either wax or polish to your car.
The best way to apply polish or wax to your car is not in a circular motion but a horizontal left to right (or right to left) motion.
Not sure if he's completely right but one thing is for sure. He has
virtually NO swirl marks......but I on the other hand....do.
Old May 10, 2002 | 03:39 PM
2K255HP's Avatar
My car is less then 4 months old and i already see swirls
it was posted somewhere that the swirl marks are a result of the clear coatings put on the car
I went to the dealer and noticed that even those cars have swirl marks on them
But come on less then 4 months
Not from wax or polish because i haven't even done that for my car yet
about to soon
hopefully today
I read to be safe you should wax your car for 3 months i don't know something about the clear coating
Old May 10, 2002 | 04:37 PM
SptBiz's Avatar
[QUOTE]Originally posted by 2k2maxima
[B]Hey how's it going guyz, i just recently noticed some swirl marks on my hood - they seem like scratches but I'm not quite sure how it happened as I wash the car at home, maybe from the way my friend waxed it???!?!?!? I only see these scratches if I look at the car at a certain an angle?!?!?!? Someone pls. let me know if I can do something about it.....
This is getting interesting. I also have swirl marks & scratches on my hood. Mainly on the upper quandrant of the hood on the passenger side. Only visible under certain lighting conditions & angle. I've tried Scratch-X but I can't get them out. Nobody here has any idea how they got there ? Hmmm ?
Old May 10, 2002 | 06:21 PM
hawks25's Avatar
As your all not surprised to hear, my 2k2 has/had swirl "type" marks on the hood. I used Meguiars Show Car Glaze (hand applied with terry cloth bonnet and removed with clean diaper from kids' closet) and it seemed to have a much more uniform look to it (I wouldn't say they completely went away), not to mention the deep black that resulted.
But the funny thing, when I applied the Meguiars High Tech Yellow Wax (good ol' #26) afterwards, the depth of the black went away a little. Maybe I should have washed the new bonnet first.
When I applied the Glaze, I used an "oval" motion, going with the lines in the car (from front to back, vs. side to side or circular). I was told that when I was growing up. Dad: "Son, you want to wax a black car....."
The Glaze has no wax, it is a polish. But just being on their website, I've found that they have a "New Car Polish", which basically sounds the same, with the only difference being that it requires "very little effort."
Cheers.
Old May 10, 2002 | 07:58 PM
emax02's Avatar
The best way to avoid swirel marks is to wax using a up and down motion rather then a "swirl" motion. Also when you wax make sure you use a brand new 100% white cotton towel. Another good way to avoid swirles is to not dry your car by hand, pour the water from the hose so it pushes 95% of the water off and then you are all set.
Old May 10, 2002 | 08:54 PM
Later...
You can get the 3M Swirl remover for dark colored cars at Pep Boys.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
leatherneck
Sep 30, 2015 09:16 PM
