synthetic blend oil ok?
Old May 10, 2002 | 07:18 PM
nismax77
Thinking of switching to synthetic blend engine oil. But the 01 maxima manual states "do not mix mineral based and synthetic type oils in the engine at the same time."
Some people on this board are using synthetic blends.
Does this apply to synthetic blended formulas or only to mixing manually between a full synthetic and conventional dino oil?
John
Old May 10, 2002 | 07:27 PM
Deven2kStickMax's Avatar
Re: synthetic blend oil ok?
John
nobdy would want to mix the two oils in the engine at the same time. just try the synthetic after about 15,000 miles. i just past 10,000 and i'm already using MOBLE1 .it's impressive and smoother shifts.
Old May 10, 2002 | 07:29 PM
Blackgums100's Avatar
John
Switch it up asap. Use a good one like Amsoil, Havoline, etc.. You should probably take a look at the Oil Analysis that's a sticky on the General section.
Old May 10, 2002 | 07:35 PM
Highlander's Avatar
Blends are a bit of a waste. Go one way or the other - synthetic or dino...
Old May 10, 2002 | 07:40 PM
true
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
