Is top speed in 5th or 6th?
Old May 11, 2002 | 08:28 AM
Jaws's Avatar
Was out for a run yesterday afternoon and decided to "see what she'll do". I was on a stretch of 2 lane country road with a slight incline and nobody was in sight. Took it to redline in 4th and then left it in 5th but could not get it to rev any higher than ~6k rpm which was an indicated 225 kmh (~140 MPH). I shifted into 6th which was about 4500 rpm at that speed when I had to slow down as an intersection was fast (VERY fast) approaching. So is 6th gear faster or is 5th? The wind was pretty variable at the time and, as mentioned earlier, I was going up a slight hill--so I potentially could have gotten a few more klicks out of the speedo in 5th. BTW the Max felt solid at that speed and the car was vibration free.
Old May 11, 2002 | 10:00 AM
Stereodude's Avatar
Re: Is top speed in 5th or 6th?
It's questionable. The numbers seem to point that 6th and 5th should do about the same speed. They're close regardless of which way it falls.
Stereodude
Old May 11, 2002 | 10:09 AM
chinaonnitrous1's Avatar
if i remember..i did redline 5th gear...and dump it into sixth...in my sig..thats 6th gear..with a few thousand left on the tach....
Old May 11, 2002 | 10:12 AM
Bigdyl's Avatar
i got my auto 2000 se to break 140 on the speedo last night, but it wouldnt rev past 4.5k rpm
Old May 11, 2002 | 10:23 AM
Thought automatic 2K max's had speed limiter @ 133mph
Old May 11, 2002 | 10:24 AM
hey hogan.....how aboutta... nos kit onna 2k2?...i thought you had one on your pathfinder motor....whatcha think?
Old May 11, 2002 | 10:26 AM
Bigdyl's Avatar
i only said the speedometer read 140
Old May 11, 2002 | 10:33 AM
Jaws's Avatar
Are you sure that's 6th? You are already at 6k in the picture. Which would be about 175mph in 6th!
Old May 11, 2002 | 10:35 AM
yea..your right..i do remember 80 is about my top speed in 3rd..about 123 in 4th..so yea..thats gonna be 5th
Old May 11, 2002 | 10:38 AM
It was worth it, why do you ask ?
I doubt it will allow you to go any faster, but definitely quicker.
Using NX Wet System jetted for 75 shot, ZEX system has been sold to a NYS Resident w/ a Maxima.
James92SE
142
Jan 2, 2024 09:23 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
hot04
Sep 18, 2015 06:14 AM
Maxxx10
Sep 13, 2015 03:16 PM
