Quad exhaust tips = V8?
To the laymen that's usually the case, 1 tip = 4 cylinder, 2 = 6.. etc. Though i know it's not usually the case, but i am curious. Do you think that alleged 6th gen Maxima that Brian dutifully shared photo's of sports a V8 under the hood?
As i posted in his thread i did notice 4 tips emanating from under the rear bumper (after some lighting correction)
What can one guess from that? Or is it just too much of a variable that it's worthless guessing at this point.
The exhaust look is all cosmetic. Most cars don't have true dual exhaust. If they did there would be two mufflers, two cats, and two pre-cats. In other words the headers on either side would have there own exit system. four cylinder engines can't have true dual exhaust systems. My point is most manufactures do it for cosmetic reasons.
Originally posted by swallac2
The M3 has quad exhaust (only two mufflers). My old Firebird Formula V8 had one muffler, with two outlets. It's really up to the manufacturer. Most trucks only have one outlet.
Originally posted by lcf
alls i know is that is a fugly car.
the 5th gen grew on me, but there is no way this will.
The Altima 2.5 has two tips and it's a 4 banger...so did a bunch of other cars.
I don't know where this rumor is coming from but there is no way that they can put a V8 in this car. The next generation Max is based on the Altima platform which is FRONT WHEEL DRIVE! All these guys that keep speculating about a V8 Max have no foundation in fact. I seriously doubt that Nissan can stick a V8 in this platform and if they did, it would be so plagued with torque-steer it would be dangerous to drive.
My hope would be the VQ35 at around 280HP and AWD from the Murano, which is also based on the Altima. And an option of the CVT from the Murano or a 6 speed Just a thought.
Re: um...
Originally posted by noflash
I thought we had already established that it would be RWD w/ the 8 as an option - no torque steer there.
Re: Re: um...
The 2004 Maxima is based on a FWD platform - you must be still on the 350Z topic which is RWD.
Re: Re: Re: um...
Originally posted by Newman
all of these are rumors. neither of you know for sure.
Re: Re: Re: Re: um...
Read the story on the main page of this site www.maxima.org. I think it's a pretty valid source.
Re: Re: Re: um...
Originally posted by Chinkzilla
Since when does a platform denote exclusivity to one form of drivetrain? Please explain to me why they can't just turn the engine 90 degrees add a drive shaft to a rear differential and make it rear wheel drive. Your logic is beyond me.
Can't do it. This is not possible in a car designed from the ground up as a FWD vehicle. Too many issues with engine mounting, transmission mounting, drive train clearances, torque dispersion, rear suspension mounting, shift linkages, weight transfer, handling changes, etc, etc.
Re: Re: Re: Re: Re: um...
I didn't see anything about RW/FWD in those articles.
Think about it, this has been discussed before. IF the new Max was gonna be rear drive it would be based on the FM platform (350Z, G35, G35 Sport Coupe) or the Q45 platform (Q45, FX45, M45). Why and how would they reverse engineer a front drive platform to rear drive when they already have two succesful rear drive platforms?
I think your underestimating the abount of engineering invoved.
The only thing that would be reasonable is FWD or the AWD system from the Murano. The Murano, which is based off the Altima, still has a horizontally mounted engine so the only new platform enginearing involved is making room for a driveshaft, rear diff and axles.
Making it V8 RWD is completely illogical since we know its based off the Altima.
Re: Re: Re: Re: Re: Re: um...
Originally posted by 97GLE
Ugh!!!!
Ugh!!!!
We need to put to rest any thought of a RWD V8 Max at least for the 6th generation.
yes, it's all speculation but...
Come on. We must be missing something. There is no way the next gen Max will come out with less than 260hp. The next logical step is a V8 pushing near 300. The 02's have tons of torque steer as they are now. I don't see how the 6th gen can be FWD - no way. Also, not that they know a damn thing, a local dealer here said RWD is what he heard.
Let's compromise and say the most logical step is an AWD V-8 with an ugly butt.
Re: Re: Re: Re: Re: Re: Re: um...
Good point 97GLE. Given that the Murano platform has AWD, it is remotely possible for AWD in the Max but I suspect the added weight could offset any significant performance increase. I'd also hate to think about how much that would cost, though.
Re: yes, it's all speculation but...
Re: Re: yes, it's all speculation but...
The reason the 2k2 max has a lot of torque steer is because this platform has been around since '95. It's a throwback to when Nissan was cutting costs. From what I've heard tourque steer isn't noticable on the new Altima, and don't think it cant be done. My friend has a CL-S and as much hate as people have for those cars, they have plenty of power and no noticeable torque steer.
BTW: I LUV TORQUE STEER ~~~~
G
Re: Re: Re: yes, it's all speculation but...
Originally posted by 02MaXiMa_GLE
Uh... my friend's TL-S has PLENTY of torque steer, even with the stability control system on!
G
G
I'm not bashing the Max, just saying that their are many options to minimize torque steer on front drive cars. If the Maxima goes RWD then the price will skyrocket or they will have to make the interior comparable to the Altima. Im just trying to make the point that RWD V8 is unlikely, an not necasarily the best option.
06-06-2017 02:01 PM
