UDP Dynojet Results, 2K2 VQ35
Old May 16, 2002 | 05:21 PM
GregP's Avatar
I finally had the car re-dynoed with the UDP. Results are predictable! Click the link to the left to see the dynojet graphs.
Old May 16, 2002 | 05:42 PM
Maxtor
Nice gains. Especially the HP!
Old May 16, 2002 | 05:44 PM
CIRCO's Avatar
Re: UDP Dynojet Results, 2K2 VQ35
Nice job on postin those pics Greg! So an increase of 3.6-5.4hp I guess for just changing a pulley thats awesome!
Old May 16, 2002 | 05:47 PM
ssiperko's Avatar
KLOOGY....Yer ???? is answered!
Very nice gains! Seems very worth the $$$ spent huh?
l8tr -- SS
Old May 16, 2002 | 05:48 PM
Donkey®'s Avatar
wat
Hey Greg...I get mine done tomorrow. Hope I get some good results!!!! You better watch out, you may out-mod me soon!
Old May 16, 2002 | 06:32 PM
KLOOGY's Avatar
L33t BMW Drivah
AHH YES ! You just answered my question, and chose my next mod for me !
Old May 16, 2002 | 06:59 PM
emax02's Avatar
Thanks for doing this Greg. Are these dynoes SAE correcterd and could you also post the Barometer level of each run(before and after)? Thanks
Old May 16, 2002 | 07:31 PM
soundmike's Avatar
Very sound, Mike
It's still not SAE corrected. Both the before and after runs. Greg, can you ask the shop to give you SAE corrected graphs? That way we can see if the gains are attributable to the UDP and not just environmental factors.
Thanks.
Old May 16, 2002 | 08:57 PM
SmokinOdum's Avatar
nice, i guess i know what to save up for next
Old May 16, 2002 | 09:05 PM
BioMaxDDS's Avatar
Greg if you don't mind me asking
how much did you spend total? and where did you get it at?
thx
Old May 16, 2002 | 09:07 PM
KLOOGY's Avatar
L33t BMW Drivah
The UDP's go for $180-200 , not an expensive mod ..
Old May 16, 2002 | 09:16 PM
02MaximizedVQ's Avatar
Is the factory pulley a harmonic dampener?
Old May 16, 2002 | 09:57 PM
Newman's Avatar
im just curious. on your pre-UDP runs:
if HP is derived from torque how did you get more torque on run 3 than on run 2 but less HP?
soundmike...care to take this one?
Old May 16, 2002 | 10:39 PM
emax02's Avatar
No
Newman, that's normal.
Old May 17, 2002 | 04:59 AM
GregP's Avatar
Hi Guys,
All of the dyno runs are "STD Corrected" which is how the dynoshop does it. On both my "before" and "after" dyno runs, the days were essentially "perfect" so there is virtually no difference in STD, SAE Corrected, or Uncorrected runs. They brought them up on the screen to show me, but as I mentioned, there was virtually no difference. The SAE Corrected graph(which I don't have) was about 1 hp and 1 lb-foot of Torque LESS than the graphs I posted.
The dyno runs didn't cost me anything because they were done by Unorthodox Racing for their web site. The normal charge where I went is $60 per run, by appointment only.
The UDP labor was free (remember - my car was the very first 2K2 test mule fitted with the new pulley, so Unorthodox did not charge).
Greg
Old May 17, 2002 | 05:49 AM
soundmike's Avatar
Very sound, Mike
I'd like to... but i don't exactly know the answer to that question.
Greg, STD is not corrected. What exactly is "perfect"? Per Emax, can you get the correction factor for those days just to be more accurate?
Even on your pre-dyno runs (HP-wise) you got a 5hp difference between 1st and 2nd runs.
Admiteddly, the gained torque is quite impressive on the post-UDP run though.
Old May 17, 2002 | 07:07 AM
Keven97SE
So you're saying that the differences between the actual readings and the SAE corrected values were nearly identical on both the pre- and post-UDP runs?
It's probably still a good idea to get the corrected plots. People will question the validity of the results otherwise.
Hi Guys,
Greg
Old May 17, 2002 | 07:39 AM
GregP's Avatar
Sorry - my use of the term "STD Corrected" was wrong. I should have just said "STD". The only plots I have access to are the ones I posted on my site. People can still question the results if they want to, but I'm satisfied!
-Greg
Old May 17, 2002 | 07:43 AM
ejj's Avatar
ejj
Wow...proof that they work. What will the UDP haters resort to now?
Old May 17, 2002 | 07:45 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Don't let Sprite see this thread... he'll probably talk about how the results are skewed beacause they are STD.
Old May 17, 2002 | 07:48 AM
Sprint's Avatar
corrected and uncorrected can be as much as 10 - 15 hp difference.. for all we know.. he could have lost power and it showed gain.. this doesn't mean ****..
Old May 17, 2002 | 07:52 AM
emax02's Avatar
My car's STD #'s were 221.2 FWHP and 238.5 FWTQ
Old May 17, 2002 | 08:08 AM
2k2max's Avatar
Ditto! This will be my next mod after the Maxspeed.
Old May 17, 2002 | 08:26 AM
LeftCoast's Avatar
Honestly, I didn't need a dyno to verify gains. The proof is in the butt. But its refreshing to know its not all in my head. So does that mean my head is in my butt? Oh nevermind, I'm confused.
Old May 17, 2002 | 08:29 AM
Sprint's Avatar
Please see my slipping clutch theory
http://forums.maxima.org/showthread....ghlight=clutch
Old May 17, 2002 | 08:32 AM
Blu's Avatar
Blu
the tits
Old May 17, 2002 | 08:46 AM
Newman's Avatar
Greg,do you have any other runs with the UDP or did you do just that single run?
Old May 17, 2002 | 09:22 AM
GregP's Avatar
We did two post-UDP dyno pulls yesterday. The first one was pretty close to the second. No two are ever identical, so you usually average them (or depending on who you're trying to deceive, take the one that makes you look best!
Old May 17, 2002 | 11:20 AM
Newman's Avatar
what were the results of the other post-UDP run? im just curious.
Old May 18, 2002 | 07:49 AM
GregP's Avatar
Newman,
Both runs were nearly the same.
TallTom
57
Oct 14, 2025 05:16 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
