Anyone noticed this on a 2K2 auto?
Old May 17, 2002 | 08:30 AM
volmax's Avatar
Has anyone noticed this on a 2K2 SE automatic?
When sitting at a red light or stop sign in drive with the brakes applied, I feel a jerking or bumping sensation through the driver’s seat. It feels as though the car has a rough idle. The car runs fine otherwise and I can’t detect any performance problems.
Any ideas on this one?
Old May 17, 2002 | 09:57 AM
Igor911's Avatar
If it is a jerking when braking in the front, it is your front rotars. To check if it is jerking from the back, go about 10mph and push your emergency brake up slowly and see if the back jerks. If it does, GO TO NISSAN and get free rotars!
Old May 17, 2002 | 10:29 AM
Colonel's Avatar
Old Fuddy Duddy
I think he is refering to being at a dead standstill and feeling the "pulsing".
Old May 17, 2002 | 11:07 AM
GuZo's Avatar
I used to feel the same thing on my GLE, weird, I never paid much attention to it, I was gonna mention it to them at the 3250 service.But now the car is totalled.
SE 6 spd. coming soon.
Old May 17, 2002 | 11:42 AM
Igor911's Avatar
DAMN! that sucks...
Old May 17, 2002 | 11:44 AM
volmax's Avatar
Pulsing
Yes, pulsing is an excellent way to describe how it feels. I am describing what occurs when the car is at a dead stop and idling.
So is this "pulsing" common on the 2K2 Maximas at idle?
Old May 17, 2002 | 12:00 PM
2k2max's Avatar
Re: Pulsing
I have the same "pulsing" in my idle. The "pulsing" was bad when I first got the car, but it seems to have died down a little now; although I can still sense it.
I'm not sure what it is, does the 6-speed do this?
Old May 17, 2002 | 12:06 PM
Matthew's Avatar
Mine is the same. It idles so low at a dead stop once it is warmed up, I think the fact that it is idling at 500 rpms or less may have something to do with it... But it is a little rough, but I am a perfectionist so I notice these silly things, I am sure it is harmless.
Old May 17, 2002 | 12:26 PM
mother's Avatar
I get the same thing. Its more of a slight tremor every few seconds at idle. My 240sx did the same thing.
I also noticed that there is a vibration transered from the engine thru the gas pedal at around 2800 rpm. Anything higher or lower and it disapears. Go figure
Old May 17, 2002 | 12:36 PM
JoesMAX's Avatar
i also feel a tiny bit of a rough idle sometimes, but i have a 6 speed... when i leave it in neutral and im standing still, sometimes you feel the engine a little. on most new cars you cant even tell the car is running..
when i brought my car in today the tech said i should make an appointment for them to check out the idle, so ill see what happens. its also possible that the car needs an oil change because they say you should do the first oil change early, because of the particles that let out of a new engine and all of that
Old May 17, 2002 | 12:45 PM
soundmike's Avatar
Very sound, Mike
Nothing here. 2k2 Auto SE @ 7800m.
Old May 17, 2002 | 12:46 PM
lsondubz's Avatar
i wouldnt worry to much.. i have the same exact thing in my LS
Old May 17, 2002 | 01:32 PM
Cumalot's Avatar
It happen to me from time to time too. I have a 4th gen auto. I have no idea what cause it though. It's like the car is having a hiccup.
Old May 17, 2002 | 01:39 PM
njmaxseltd's Avatar
Did this guy actually read the post first?
Old May 17, 2002 | 01:55 PM
Young04's Avatar
"Its more of a slight tremor every few seconds at idle."
Exactly what my car does. I have a 2002 GLE with just over 1000 miles on it, and this tremor started occuring around mile 600 or so. Very slight though, and I've definitely experienced it in higher end cars are well...so as long as it doesn't get too much worse, I dont think that we should worry. I did my first oil change at around mile 950, and it hasn't really alleviated this.
Old May 17, 2002 | 02:18 PM
TimW's Avatar
The silent but deadly Moderator
loaping...
been living with it for almost 3 years.. buy the best gas.. been to the dealer so many times I bought my own OBD2 scanner.. no luck
Old May 17, 2002 | 02:32 PM
magnum's Avatar
its probably just the engine. put it in neutral and see if it still does it. on an automatic, the engine is never disengaged, so its trying to push the car, but the brakes arent letting it. i read that in super street somewhere. if it doesnt do the same in neutral, then its just cuz the max has such a large engine.
Old May 17, 2002 | 02:39 PM
Jaws's Avatar
My dad had a 4th gen auto and it did the same thing. I recall that the idle speed was about 500 which is really too low. At faster idle on a cold start, the car was never rough. On my 5th gen, I notice the idle is slightly faster and I don't get the same sensation. Is there a difference between the idle speed of the autos and manuals?
Old May 17, 2002 | 03:34 PM
Young04's Avatar
auto 2002 gle - idles at 700 to 750 when warm. dont know about sticks
Old May 17, 2002 | 03:42 PM
Jaws's Avatar
Then the autos and mans are about the same.
Old May 17, 2002 | 03:58 PM
02MaXiMa_GLE's Avatar
I do not have this problem w/my 2k2 GLE auto... She runs smooth as silk, whether it's freezing, or hot outside. I would get it checked.
G
Old May 17, 2002 | 07:45 PM
KLOOGY's Avatar
L33t BMW Drivah
Never felt it...
Old May 17, 2002 | 08:08 PM
emax02's Avatar
I have a little pulse here and there, I always figured it was becuase of the intake but now I don't know. It does not really bother me buch, althought it scares me a little becuase of bad memorys of my 98 I30(staling problems).
Old May 17, 2002 | 08:28 PM
2K255HP's Avatar
Good good someone without the problem
startin to scare me
I for one have not noticed this YET but i will keep it in mind next time i'm at a red light
Old May 17, 2002 | 10:42 PM
maxbee's Avatar
I have had this happen to me also. I just did a old school trick of puting a strip of paper over the tail pipe(while hot). If at any point the paper gets sucked slightly back into the tail section then its a case of a small misfire. After I tested my car it tried to pull it in on a few ocasions so I just upgraded to to platium spark plugs and the problem went away. Note-Make sure its not idling to low, are else this will cause a small misfire also. 700-800 rpm will be ok. This trick works on all engines.
Old May 17, 2002 | 11:08 PM
emax02's Avatar
The maxima comes with platinum(NGK) spark plugs stock, what brand did you use?
Old May 17, 2002 | 11:59 PM
maxbee's Avatar
Bosch +4's.
Old May 18, 2002 | 04:01 AM
Larry's Avatar
Mine is smooth as silk at idle. When I give mine throttle too fast I get a jerk though. I have to throttle slowly to get smooth acceleration.
Old May 18, 2002 | 10:03 AM
GimmeTorq's Avatar
Yep, in PARK or NEUTRAL I don't feel it. In DRIVE, I do. I don't feel it thru the steering wheel but thru the seat. In DRIVE and in a complete stop, car idles at 650 rpms. BUT what ****es me off is that it doesn't do it all the time. It didn't used to do it when I bought it and after around 1200-1500 miles, it started to do it. The car was babied all the way thru break-in. I was wondering if has anything to do with the brand/reformulated gas we get here in the Midwest. I always use Mobil 93. have tried different Mobil stations. Maybe I will try filling it up with Shell or Amoco. Buddy of mine doesn't feel anything like that in his 2001 SE...
Old May 18, 2002 | 10:29 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
I read in some mag that the idle speed on cars is being set extra low these days to help with emissions so that could be part of it, especially on automatics where you always have a load. My Accord V6 sorta did something like this when I had it. Every once in awhile you would feel a sort of bump or pulse but it wasn't rhythmic or predictable or anything. After upgrading to Denso Iridium plugs I never had the problem again, but the stock plugs on Accord V6's are the crappy "100,000 mile before tune-up" garbage variety and not NGK's like on the Maxima.
Do you guys still have this problem with the A/C OFF? Low idle for emissions + automatic tranny load + A/C compressor drag can lead to a lumpy and sorta rough idle I guess...
Old May 30, 2002 | 09:19 AM
Eric's Avatar
Anyone figure anything out on this
Did anyone with the pulsing issue ever resolve the problem?
My 2k2 6-spd is currently in at the dealer trying to get this rough idle thing resolved. Its pretty much the same symptoms described here.
Irregular pulses, of varying intensity which seem to be coming from the engine. I don't see a jump in RPM, nor do I hear anything, but I definitely feel it. I only feel it when I am sitting at a stop, car in neutral, foot off the clutch, waiting for the light to change.
Most of the pulses are pretty mild, but occasionally they are strong enought that passengers ask me what's wrong with my car. Its kinda embarrassing, given the price of this vehicle.
I took it in before for the same problem and they changed all 6 coils, but the problem persisted.
Old May 30, 2002 | 09:41 AM
CHAZMAX's Avatar
Re: Anyone figure anything out on this
All I can say is... This is obviously a VERY REAL problem in some late model Max's. I personally don't have this problem. I know for a fact, since I have sat in my car w/ engine running for extended periods and absolutely no problems. (specifically in 'drive') It's this very fact that confirms that NOT ALL Max's are exhibiting these "pulses". Therefore, COULD and SHOULD be fixed. I would bring it to dlr asap!
Good luck everyone!
Old May 30, 2002 | 10:09 AM
MetaOrbit's Avatar
Got Projectors?
You know, I have about 1600 miles on my I35 and the only kind of pulsing effect I feel (which I noticed in a parking lot yesterday) occurs when I have the A/C on. The pulsing bothered me, so to experiment I shut the A/C off and it went away.
John
Old May 30, 2002 | 10:17 AM
Eric's Avatar
I had thought it was this way back when, so I totally shut off the climate control and radio, and the pulses were still there.
John
Old May 30, 2002 | 02:39 PM
FrankY2K2's Avatar
I have about 3500 miles on my car and no pulse or rough idling at full stop on "Drive", idling at around 600rpm. However I never turn on my A/C (I don't like the idea of having like 30% of my power being sucked up ).
I usually feel a pulsing at an idle stop when the a/c is on in my other cars tho.
-Frank
Old Jul 12, 2002 | 09:22 PM
GimmeTorq's Avatar
Update
Well, about 5 weeks ago decided to try Shell premium and the "pulsation" is now nearly gone. I think I'll stick with Shell gas for a while...
Old Jul 12, 2002 | 11:59 PM
saxdogg's Avatar
Re: Update
2k2 auto w/ 25oo mi. I have noticed that my bumpy idle (stopped at light) has smoothed out with age. It's getting better, but I DEFINITELY noticed it when it was brand new...
Old Jul 13, 2002 | 08:11 AM
pvaudo's Avatar
Re: Anyone noticed this on a 2K2 auto?
2002 GLE auto, 1500 miles... no symptoms here
Old Jul 13, 2002 | 12:26 PM
Maximus1000's Avatar
My 2K2 6spd has the infamous lopey idle as well. One day when I drove back home after an hour or so of driving, I parked and raised the hood with the engine still running. You could see the engine itself shaking a little. I'm not talking about shaking uncontrolably, but it did have a prominent jutter. So its either the idle is too low, or the motor mounts aren't designed properly.
Old Jul 13, 2002 | 01:46 PM
Virus's Avatar
My max does the same thing. This may sound funny, but it stops when I use Amoco or Shell gasoline. When I use Texaco, Mobil or any other gasolines, I get a rough idle at stop.
