9003/h4
Old May 19, 2002 | 03:28 PM
SLC I30t's Avatar
9003/h4
What is the real difference? I mean I know(NOW) that they are the same bulb type. But they have different names so there must be some differnce. Are H4's normally an aftermarket wattage? Are H4's like a metric size of lightbulbs?
Old May 19, 2002 | 07:13 PM
Igor911's Avatar
H4 = 9003... They just have diff. names but are all the same bulbs.
Old May 22, 2002 | 09:32 AM
Albertt's Avatar
Re: 9003/h4
Supposedly, 9003s are built to tighter tolerances than H4s. Or vice versa. Performance-wise, you probably won't notice it.
The ANSI #9003 is a DOT designation for the bulb that an HB2 housing uses
H4 is an SAE/ECE term for that bulb.
I wouldn't worry about the nomenclature...just remember that it is the best dual-filament bulb on the market. An overwattage bulb (not 55/65), whether refered to as 9003 or H4 is not DOT or ECE approved for use on road. Also, I would not use an overwattage bulb without using a special harness with beefier connectors, wiring and higher amperage relays.
Ray Torres
Nov 4, 2014 12:51 PM
NissanTun3r
Jul 6, 2010 08:41 AM
blkonblkmax
Apr 5, 2009 04:42 AM
ressling
Feb 21, 2006 08:01 PM
