emergency blinker rewire went wrong
Old May 20, 2002 | 06:27 PM
donmaxima's Avatar
how do you rewire the back blinker sidemarker so it will look like he front one where it blinks together, or it blinks alternately, i tried something and messsed it up, please help , if anybody did this please tellme!!!
Old May 20, 2002 | 06:30 PM
RussMaxManiac
Re: emergency blinker rewire went wrong
Search is your friend:
http://forums.maxima.org/showthread....+corner+rewire
Actually here is the correct method...
for the back, take the back panel apart to access the rear lights and basically connect the TURN SIGNAL light's BLACK wire with the SIDEMARKER's black wire in the same fashion as you did in the front. (cut Sidemarker black wire, wrap end going into car, buttconnect with new wire and splice/tap into rear TS black. wrap and put together.)
Old May 21, 2002 | 06:17 PM
donmaxima's Avatar
Re: Re: emergency blinker rewire went wrong
when i clicked on the link the other people in the other forum say you have to top into the green wire but your saying tap into the balck wire, i am really confused please help me
Old May 21, 2002 | 06:20 PM
RussMaxManiac
Re: Re: Re: emergency blinker rewire went wrong
Check the site again, the rewire was updated. That is the actual way to do it, not this.
Old May 22, 2002 | 04:25 AM
donmaxima's Avatar
Re: Re: Re: Re: emergency blinker rewire went wrong
ok thanks alot will do ASAP
Forge277
Jun 13, 2016 09:26 PM
Sir Tilus
Mar 22, 2016 01:49 PM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
