bumpstop trimming
Old May 22, 2002 | 01:12 PM
noflash's Avatar
bumpstop trimming
I get a nice BAM! from the rear from a dip or bump in the road traveling at ~45mph or greater. I have Maxspeeds and stock GXE struts. Galo recommended triming an inch off of the rear bumpstop - sounds like good advice, but...
I called my install guy (give him a break it was a month ago), and he said, if he remembers right the rear bumpstops were part of the dustcover and he would have had to throw that whold part away to trim them? I am having a hard time visualizing all this - I know what dustcovers look like, but not bumpstops. So, he's going to take a look on Friday. I just wanted to give him a heads up on how to trim maxima bumpstops. Any guidance?
PS I already fixed the Addco Bang - grinded
Old May 22, 2002 | 01:43 PM
CIRCO's Avatar
Re: bumpstop trimming
I might be wrong on this one but I believe the bam you are hearing is from your stock GXE struts. The aftermarket springs are smaller than stock and thus reducing the amount of travel for your strut. So everytime you hit a bump your stock struts are bottoming out because it is not matched to the progressive rate spring you have on.
Old May 22, 2002 | 02:00 PM
noflash's Avatar
Re: Re: bumpstop trimming
I hear ya, and I am considering Toks. But still Eiback instructions call for trimming the bubmstop regardless of struts. And to clarify, it's not every bump. It's gotta be big and I have to be at ~45mph.
Old May 22, 2002 | 02:34 PM
CIRCO's Avatar
Re: Re: Re: bumpstop trimming
You know I heard Galo say that Eibach said that but I don't think I have directions for install. Maybe I didn't look too good. All I found was 2 stickers, warranty, and brochure.
Old May 22, 2002 | 04:19 PM
srbarnes4ever's Avatar
Re: Re: Re: Re: bumpstop trimming
Galo is very correct. I have the instructions as well and they say specifically to remove 30mm from the front and 26mm from rear bumpstops. When I removed my spring perch from the rears, the dust cover was separated from the lower bumpstop. I took it out, trimmed it and reinstalled everything with Eibachs and didn't have any trouble. Good luck!
Old May 22, 2002 | 04:45 PM
CIRCO's Avatar
Re: Re: Re: Re: Re: bumpstop trimming
How the hell did you trim it? Isn't the bumpstop made of some dense rubber?
Old May 22, 2002 | 07:04 PM
Audtatious's Avatar
Bandwagon Lover
Re: Re: Re: Re: Re: Re: bumpstop trimming
Since the bumpstops are there to stop excessive suspension travel, wouldn't trimming them potentially cause early strut/shock wear due to excessive travel?
Personally, I left them alone until I get a set of AGX.
Old May 22, 2002 | 07:05 PM
noflash's Avatar
I just got an email from Galo and he said he had to destroy the dust covers to get the bumpstops trimmed. He then replaced them with a used set he had.
I'm pretty sure he's got a '01 too. So what gives? How come yours weren't integrated?
Old May 22, 2002 | 08:11 PM
The dust covers were integrated, but while removing the upper perch, they separate quite easily right at the base of the bumpstop, leaving the dust cover to stay on the shoct shaft.
I used a hacksaw to trim the rear bumpstops.
Since you lower the car, you have to slightly reduce bumpstop length to gain back a bit of the compression travel the shock has, otherwise you end up riding on or near the bumpstops and every dip or bump is a jarring blow rather than a near stock compression against the bump rubber. I would expect anyone who lowers their car without trimming bump stops to have a harsher than necessary ride.
Old May 22, 2002 | 08:18 PM
noflash's Avatar
Re: Re: Re: Re: Re: Re: Re: bumpstop trimming
Okay, I'll print this and bring to my install guy on Friday. Still I wonder if there wasn't some mid-year change? We'll see...
Thanks for the explanation.
Oh yeah, if I get Toks will all of this be moot? I mean will the Tokicos come with their own dust covers and bumpstops?
Old May 23, 2002 | 07:59 PM
Galo's Avatar
Maxima Pilot
Hey..checking up on me, eh? LOL!!!!!!!
Like a major surgical procedure...good to have a second opinion!
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
