What intake has the least amount of the whistling noise?
I have a JWT popcharger and with the warm weather it's really getting on my nerves when I have the window open. I just touch the gas and it whistles. It almost sounds like bad brakes and it's kind of embarrasing.
Originally posted by BlackMax2k1
What about without modifying my car, ie cutting a whole?
Isn't it better to cut a hole through the splashguard?
Originally posted by asu174
Part of my splash guard must be missing because I was able to run it down and just attach it with an L Bracket. Open air galore....
Hey asu174 did you trim your bump stops. I did the install today and the bumpstops only come off for the fronts. I have a 2K GXE. Might be different for the 2k1 AE's I don't know. For the rears I trimmed the bump stop and had to ditch the dust boot. BTW looks like you are leaking oil there.
Re: What intake has the least amount of the whistling noise?
Sorry to hear about your whistling, but I am soooooo glad I am not the only one experiencing this problem. Everyone keeps telling me this is normal, but I don't agree. My Frankencar is so bad I'm either going to have to find a solution or get rid of it.
Tony
Re: Re: What intake has the least amount of the whistling noise?
Originally posted by Tony Fernandes
BlackMax,
Tony
BlackMax,
Tony
I'd recommend you hang tough with the Frankencar intake until after you've installed your Y-pipe. You're going to experience some hissing from the pipe as well. The two sounds may tend to cancel each other out. Or they may complement each other as they do in my case. But I'm sure you realize that it's not realistic to mod your intake and exhaust and expect your car to remain as quiet as it was with no mods.
I've had the following intakes on my car:
Berk Tuning LE w/ Apexi intake
Berk Tuning
Stillen
JWT
Out of all the intakes the Berk Tuning LE intake is the quietest. Reason: The filter is constructed using injection molded plastic, this material actually kills resonance. You can still hear it but it is much less pronounced. The Stillen/JWT are by FAR the loudest "squeakers".
Berk Tuning
Stillen
JWT
I honestly have no idea about the bumpstops. I don't even know what a bumpstop looks like. When I bought the car, the coils and springs were on there (which was a MAJOR selling point for the car).
Berk Tuning (Standard)
Stillen
JWT
Stillen
JWT
3 of us looked through Tony's intake, and couldnt quite figure, where the hissing was coming from. It's puzzling. I have no hissing whatsoever, just a loud Roar . The berk was fine, but it's too quiet for me, so I just added the Franken -Mid pipe.....so I have a Berk, with a Franken Midpipe !. Perfect for me.... Im giving a CAI some thought..Im waiting for some info. Sucking Air from a HOT pavement, like i've explained before is not A CAI.... I will continue to explore...
I disagree,.... they are both HOT. The difference in heat, between one and the other, is not enough for you to charge a customer 120.00 more for your product. There has to be a way of getting that piping to a true Cold area.... Im approaching this issue from a Southern California point of view. I know weather conditions, are different in other parts of the country. If you live in Vegas, any intake will be HOT ! ..... Have you ever seen the Vortech system that uses an aftercooler, with ICE in it ?
PS: It appears that instruments used to measure pavement heat have an upper limit of 200 degrees F. So I'm assuming that's as hot as pavement ever gets. So the next question is, how hot does an engine bay get on a hot summer day with a fully-warmed-up engine running at idle?
Re: Re: Re: What intake has the least amount of the whistling noise?
Originally posted by y2kse
It is normal, Tony. The only other thing that could produce the whistling sound you're referring to is an air leak in the intake, and that would probably throw a SES light.
I understand that modding will make the car louder. One of the reasons I chose the Frankencar intake was the WOT throttle sound. But whistling? I've NEVER heared any other car do it...and there's tons of cars around here with all sorts of mods, including intakes. I had a friend of mine drive the car past me while it makes the whistling noise and it sounds severely retarded. Never heard anything like it.
Isn't it possible that the whistling sound BlackMax and I hear is more than what you call normal?
Anyone have a digital recorder that can record their whistling so I can hear what normal is supposed to be?
Tony
If you cant figure out where it's coming from Tony, I would just put the stock intake back on, mayme try a Place Racing CAI, or something different. That is the weirdest thing Ive ever heard. Then again, after seing the 2K-2K1 setup, for the midpipe, there is more of a chance for that to have a whistle, than a 2K2....... If your engine bay got as hot as you are thinking it gets, dont you think the plastic components would be melting. I know engines get HOT, I owned 2 V8's , but I think you're also forgetting that cars have ventilation into the engine bay, the moment you accelerate, Air is RUSHING in there. I want to see someone test a Frankencar, or any other Short Ram, VS any CAI, on the same car , in the same weather. I'm sure that if there is ANY difference at all, it wont be worth the money you have to pay some of these companies who are asking close to $300 for CAI's... It just like the Exhaust issue, is that extra $350 worth saying, I have a Greddy.... Modding all goes back to the individual's opinions, on what they favor, ... It's just my opinion, just like I object to the VB mod...
I'm with Y2KSe on this one, although I agree with you Kloogy that there is no such thing as a "cold" air intake. The CAI's out there (ooglie and $200 ones) are more or less "not nearly as hot as the engine bay" air intakes. It also helps with general circulation. You can cook bacon on an engine in AZ in the summer. Pavenment gets hot, but not nearly as hot as the engine.
The $16 I spent at Home Depot....well I'd say I got my money's worth. But I wouldn't spend much more than that.
You can cook bacon on an engine in AZ in the summer. Pavement gets hot, but not nearly as hot as the engine.
I looked around for a bit but I couldn't find anything that talks about how hot it gets under the hood of an automobile. But pavement won't ever get hot enough to cook chicken wrapped in foil even on a summer day.
The CAI is a very good intake. It's only fault is that it doesn't breathe as well as a POP at high rpms. There's alot I miss about my CAI. I've changed to a Hybrid now.
In terms of sound, the CAI rocked. Totally silent until WOT throttle, then it was LOUD, but always a nice loud.
The hiss is there with the CAI, but even with the windows open, it wasn't very loud. The hiss sounded cool, like a slithering snake that's just about to POUNCE
In terms of cold air, the difference between POP and CAI may not be that much in terms of temps, but one thing is that the CAI was always more consistent and linear. My Hybrid is better up top, but the low end is not quite what the CAI was. You always knew what the car was going to do once you florred it, now, with the Hybrid, for a few moments you'r like it will go faster, then it does.
One thing I don't miss about tthe CAI is cleaning the filter. It was always a Bi#$%TCH to get to!
Once I get a VI, I may go back to CAI, though.
DW
DW
depends on if u decided to build a ram air and with that, most likely water might get in....but can it travel to ur air box? I doubt it. unless u drove into a river.
and yes, it is just an extention that replace the tube to the air silencer
Originally posted by Triple8Sol
The OSCAI everyone talks about...correct me if I'm wrong, but isn't that basically just some open piping running from the current piping, down to the bottom of the car? What happens to road debris, water (it rains alot here in Seattle), etc...?
True, my friend. But I doubt there's any pavement in the world that gets hotter than an engine bay with the engine idling on a blistering summer day.
If that is the case...figure you are parked with your car running. With a typical WAI (Franken, JWT, Berk, etc.) the intake is located near the top of the engine bay. We all know warm/hot air rises right? Since there is no place for the hot air to exit, I would think the air would be become very hot and stagnant at the top half of your engine bay. Now, if this is all in fact true (maybe/maybe not) I would much rather have an intake sucking air off of a 200-degree pavement then right in the mist of all of the hot air. Remember too that the hot pavement will also add to the overall temp in the engine bay as well (hot air rises).
Is that worth the extra money? That will be up to you.
I have a franken right now, but if the Injen intake is as nice as claimed (CAI without drilling/cutting and good HP gains) - I will probably change. My only concern with the filter close to the ground would be getting water in the intake.
My .02
Brian
Originally posted by TellschMax02
. . . if the Injen intake is as nice as claimed (CAI without drilling/cutting and good HP gains) - I will probably change. My only concern with the filter close to the ground would be getting water in the intake.
My .02
Brian
My .02
Brian
And according to the tech at Injen, you can add an AEM bypass valve if you're concerned about water getting into the CAI.
I don't mind hissing, roaring, sucking, sipping, or any other intake sound. This is a very high-pitched whistling sound, like bad brakes. I wish I had a way of recording it for everyone to hear.
Originally posted by maxman00
Sorry for my ignorance, but what is an AEM bypass valve?
http://www.aempower.com/induction.htm
And disregard AEM's admonition that the Air Bypass Valve is for use on AEM Cold Air Systems only.
I know exactly what you are talking about! Mine makes the same high pitched screeching noise! for the most part, I only notice it when I am in 2nd or 3rd and jerk the throttle quick. For a split second after I do that, what I hear can be compared to your bad brake analogy. This should some as no surprise, but I noticed it more when I added the mid-pipe.
Unclejunebug
04-02-2016 05:42 AM
Need help
23
10-02-2015 08:56 AM
DC_Juggernaut
09-28-2015 04:07 PM
