To trim or not to trim (bumpstops)...
Old 06-04-2002 | 09:59 AM
  #41
Maximam's Avatar
Originally posted by noflash
Well, I have Maxspeeds on GXE stock shocks and I currently bottom out. If Toks have the same compression rate, I will still bottom out. If I trim the bumpstops, I will not bottom out.
Where's the debate?
If you bottom out, trim; if not, don't. Plain and simple.
Now somebody put this in the FAQ, cuz I am done discussing it!
Your stock struts/shocks are the reason for the bottoming. Nissan Maxima shocks are WAY too soft especially in the rear, both 4th and 5th gens!
Again I always recommend cutting the bumpstop AND replacing the struts/shocks with A SPRING CHANGE. A spring change without a strut/shock change is like changing the oil rings and just leaving the old compression rings. But springs are $200 and shocks are $600 hence the majority of cars running around with stock shocks and aftermarket springs.
I will not do one without the other, this is why I am still stock.
Old 06-04-2002 | 10:34 AM
  #42
Blackgums100's Avatar
RE
That is also why most people install them themselves, because most shops will not do the lowering springs without the other.
Old 06-05-2002 | 09:03 AM
  #43
noflash's Avatar
Originally posted by Matthew
Thanks Brian, that does help, I am optimistic now that my almost new 02 SE struts will hold out for a while. I appreciate your feedback!
HEY! I love your new sig!
Also, just got my toks from shox.com. Bummer, I hafta what til a week from Saturday to get them installed.
Old 06-05-2002 | 09:06 AM
  #44
Matthew's Avatar
...You just love my new sig because it doesn't clog your screen... But be sure you give us your impressions of the Toks once they are on...
Old 06-05-2002 | 09:22 AM
  #45
noflash's Avatar
Will do.
Old 06-05-2002 | 11:10 AM
  #46
CIRCO's Avatar
Damn so you have to pay for installation twice! Well at least you would have done it right this time with full suspension.
REDinLV
08-15-2024 12:30 AM
jmlee44
10-02-2022 02:13 PM
JakeOfAllTrades
09-30-2015 03:16 PM
Redfox
09-28-2015 10:41 AM
Quick Reply: To trim or not to trim (bumpstops)...
