NEW TSB... EGI Harness, Wire Breakage
http://boostedmaximas.com/tsb/egi_harness1.jpg
http://boostedmaximas.com/tsb/egi_harness2.jpg
http://boostedmaximas.com/tsb/egi_harness3.jpg
http://boostedmaximas.com/tsb/egi_harness4.jpg
http://boostedmaximas.com/tsb/egi_harness5.jpg
http://boostedmaximas.com/tsb/egi_harness6.jpg
http://boostedmaximas.com/tsb/egi_harness7.jpg
http://boostedmaximas.com/tsb/egi_harness8.jpg
Credit: Mr. Anonymous and y2kse
Thanks, Kev. This TSB deals with a particularly pernicious problem. As you can see, a break in the wiring harness can cause a myriad of symptoms, some of which could easily be attributed to other causes. I'd recommend that everyone take a look at this TSB and keep it in their memory banks for future reference.
Re: NEW TSB... EGI Harness, Wire Breakage
Mil "on" with DTC stored tsb
EGI wire harness breakage
Re: Re: NEW TSB... EGI Harness, Wire Breakage
Originally posted by thicknes
they have been converted to pdf filesand zipped!!
Re: Re: Re: Re: NEW TSB... EGI Harness, Wire Breakage
Originally posted by myownnismo
what's this for.
what's this for.
I wonder if this is the cause of my 0340 DTC (Camshaft Position Sensor)... which has been on since the UDP install (when I was NA).
Maybe we damaged the harness...
I haven't had this problem but if something was to happen I will know what it is.
EGI Harness TSB#NTB01076
If a 2000-2001 Maxima has any of the following symptoms - - MIL 'On' and/or Diagnostic Trouble Code (DTC) stored in Self-Diagnosis, - Engine no start, - Other system malfunctions such as A/C inop, A/C idle up inop, rough idle, oil pressure lightinop, The cause may be wire breakage in the engine control harness where it bends over the right rear of the engine next to the right strut tower. Engine/Transmission DTC Charts are available in this bulletin for the possible DTC that may be caused by this incident, if it should occur. A Symptom Chart is available in this bulletin for the possible symptoms that that may be caused by this incident, if it should occur.
Check for more TSB's here:
http://www.nissan-techinfo.com/nissa...Maxima_A33.asp
Please email me at aleksandrkuznetsov@yahoo.com I a very desperate i need my car
magiconthetire
10-26-2015 09:03 PM
