Blazed up a CL-S
Originally posted by SteVTEC
The Acura's pull a higher trap and only manage to equal the 2k2 Max auto's 1/4 mile time because of better gearing. The Maxima still has more torque, much less weight, and better overall acceleration.
I will tell you though...I would love to see a 02' Maxima auto go against a TL-S from 0- top speed and see who would pull out. I don't want you now to go into why you would think a Maxima would win this I just want you to ponder this idea in your mind and maybe we can find two people to try this out.
Originally posted by MAX2000JP
What I find funny is that the 2k2 Maxima is just as quick with an outdated 4 speed auto. The CL/TL-S has a 5 speed auto which allows the first 2 gears to be shorter allowing quicker acceleration. I havent looked at the spec's on the Acura tranny, but Im sure it helps shave a few tenth's off acceleration numbers.
1st: 43
2nd: 72
3rd: 110
4th: 175 (to tall to pull)
5th: 245 (useless
2k2 Max auto
1st: 45
2nd: 82
3rd: 128
4th: 187 (to tall to pull)
2-3 on the Acura are a good bit shorter than on the Maxima. After the Acura shifts up to 3rd on a 1/4 mile run the shorter gear will let it accelerate harder and "catch up" to the Max and also get a slightly higher trap speed whereas the Maxima is sorta bogging in 3rd. The gearing on the Maxima isn't optimized for the 1/4 mile at all, whereas on the Acura's it is, yet the Acura still isn't any faster than the Max - but just through the 1/4 mile.
After the 1/4 mile the Maxima's taller 3rd will come into play and it'll pull trains on the Acura after 110. And if the Acura driver doesn't know his car from a roll it'll get stuck in 4th prematurely on the highway like what probably happened here. Or maybe he forgot to turn off VSA. Or maybe he forgot to turn off TCS.
Top Speed: 146.76 mph
Time to Top Speed: 186.51 seconds
Distance to Top Speed: 36,348 ft
2k2 Maxima auto
Top Speed: 147.61 mph <== FASTER
Time to Top Speed: 167.51 seconds <== FASTER
Distance to Top Speed: 32,663 ft <== FASTER
Winner: Maxima
Source: CarTest2000 Automobile Acceleration Simulation
Available at: www.cartest2000.com
Validity: It's just a simulation, but it makes sense to me. Both cars have identical drag coefficients and similar horsepower but the Maxima has better high-speed gearing than the Acura and also about 250lb less weight to pull.
God, if we asked two people to do this not only would they have to risk their own lives, but whoever lost would be arguing about tail winds, fuel loads, driver weight, and tire pressures, and no resolution would ever come of it
The simulation at least keeps the playing field level, but in the real-world of course, "your mileage may vary"
TL-S Gear Speeds
1st: 43
2nd: 72
3rd: 110
5th: 245 (useless
2k2 Max auto
1st: 45
2nd: 82
3rd: 128
TL-S Gear Speeds
1st: 43
2nd: 72
3rd: 110
5th: 245 (useless
2k2 Max auto
1st: 45
2nd: 82
3rd: 128
Steve when you get a chance, could you dig up the Maxima 5 speed/6 speed ratios compared to the TL/CL-S? I wanna see how they compare
2k2 Max auto: 2.785, 1.545, 1.000, 0.694, -----, ---, F3.789
2k2 Max 6spd: 3.153, 1.944, 1.392, 1.055, 0.809, 0.63, F3.812
95-01 Max 5sp:3.290, 1.850, 1.270, 0.950, 0.800, ---, F3.820
I'm pretty sure the 2k2 auto ratios are the same as the 00-01 models (which is what I posted), but I'm not sure, so don't quote me on that. Everything else should be accurate though.
According to CarTest2000, if an Acura CL-S is stuck in 4th gear at 80 mph, I could beat it to 100 mph by over 2 seconds in my slow-azz (and now deceased) Accord V6 where I can still downshift to 3rd.
Re: Re: Re: Re: Re: Re: Re: Re: Blazed up a CL-S
Originally posted by Golden
Sure ya did! You just keep on believing that, buddy! The CL-S is a complete dog in 4th gear. Sounds to me like you ran into a normally aspirated Eclipse with a GS-T badge. This is even more BS than the original post.
[QUOTE]Originally posted by nice95GLE
[B]Yesterday on RT 80 West in NJ I ran into a CL-S driving like a mad man, weaving in and out of traffic like he owned the road. He pulls up next to me glace over, smile and guns it. At this moment I say to the wife "he wants to play". So I started to catch up but he was still pulling a little bit, I was like WTF I know those things are not that fast. I decided to put the car in 3 from D to catch him. Once I got up to him I knew it was time to punch it, so I looked over, smile, waved bye-bye and like a bat outer hell the VQ was gone. He did try to catch me but every time he shorten the gap I would put like 3-4 car length on him. After about 2-2 1/2 mile of F**king with him I decide to let him off the hook and shut down to cruising speed.
man, you should know better not to write storries about TLS and CLS....last time i wrote about a acura burning my ***...man the entire org was on me!
Acura Type-S: 2.560, 1.550, 1.020, 0.650, 0.470, ---, F4.430
Acura CL-S
2k2 Maxima auto
Winner: Maxima
Acura CL-S
2k2 Maxima auto
Winner: Maxima
It's not like he said he pulled 3.428353 cars on him. Maybe it was only 2 cars, or maybe it was 5. Who knows.
This is exactly my point. I wouldn't have called BS on 2 cars. But I called it on 3-4. Why is it you're making such a big deal out of it? 3-4 cars is a lot to put on a car that has nearly identical performance despite the gazillion variables in drag racing. I offered an explanation of why. That's the only way I see it happening. You've harped on the idiot proof tranny several times now. The Acura tranny is no more idiot proof than any other auto tranny and it sure the hell isn't going to explain this race at speeds below 90mph.
Maybe the CL-S driver had a full load of fuel and 95GLE was on fumes.
Maybe the CL-S driver also had a passenger and 95GLE didn't know that.
Maybe the CL-S driver was stupid and had 87 in the tank and 95GLE had 93.
Maybe the CL-S' tire pressures were all out of whack and it slowed him down.
Maybe the CL-S had groceries or a small system in the trunk.
Maybe the CL-S had a broken variable intake actuator and didn't even know it was broken and never got it fixed.
The aforementioned idiot-proofed tranny not letting him grab 3rd...
2 cars? 3 cars? 4 cars? 20 cars? Geez, what difference does it make. A loss is still a loss, and your unfallable track results don't always translate to results on the streets. There are too many variables, and one or a combination of those could easily make the difference of a car or two. Since you know and understand that, why are you calling BS on nice95GLE for pulling one more car on this CL-S than he should have according to you?
Originally posted by Acura2001CL-S
The pinacle of MAG RACING!
well i know so chief there is a guy who ownes a 01 cl-s and he has comp tech headers and a cai and a few other mods and he could only shell out a 14.4 and his car was 31k so that gives me what 6k to spend on mods i think i could beat a 14.4 with 6k to spend plus i think a 14.4 is what of the best auto cl-s times i have seen but maybe i'm wrong
I don't think so chief.
I thought the General Discussion forum was bad about recycling threads OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER again.
Y'all are making poor Steve work overtime, and then you will just come back and ask him the same questions as if the answers had disappeared in a black hole somewhere.
Let's just all admit that:
Acuras ROCK!
so that the Acura members can go back to their TL world and forums.
Acuras ROCK!
Acuras ROCK!
Acuras ROCK!
I STILL can't get any of you PUSSIES to race my 02 TL-S in Denver. I always hear stories, but no one will meet for a race. It's always "I was heading north around 5:30 on...." Liars, PUSSIES. Step up to the plate all of you 2K2 SE's in Denver. I would prefer to race an auto, but I'll race a 6spd too. Step up or STFU!!!!!!
I am a manual enthusiast
Originally posted by Mustang1999
Maybe some of the people here need to grow up and stop obsessing about their cars and thinking that it can beat everything on the road. I am so sick and tired of seeing Maxima vs. Acura threads I could scream! You people need to grow up and start acting like REAL auto enthusiasts and appreciate the car for what it is, not how bad you can beat it. (Steve, I'm not talking to you.) Find something else constructive to do besides argue about petty things. Read a book, do a little volunteer work, SOMETHING besides sitting here and pouncing on every Acura thread that comes around and turning it into something ugly. *sigh* I guess some people will never learn.
uhh ok lets see some pics of you tl-s what? i didn't think you had any
i like acura don't get me wrong cause i raced the guy at tweeter and got beat by about 3/4 car length but he has comp tech headers and CAI so i should have got beat cause i have no performance mods right now but it just seems that acura guys think they are unbeatable
he has a TL-S .. he is on the TL board.. he was the one who said no way in hell could Steve run 14.3 bone stock.. but look.. Ed came around and did a 14.2
he is a maxima hater.. for a long time.. if you saw his tone on the TL Theads you would know how much he hates maxima's
well i guess that tells you i don't go to other boards starting **** then cause i had no clue but i'm not saying you do so don't take it the wrong way
The reason I like going after TL-S/CL-Ses is because they're so close competeively. 4 door sports sedan with a high power V6. Fact is, whoever wins a race between a Maxima and a TL-S/CL-S, it should be very close. Close races leave it all up to the driver.
I've raced a CLS in Manhattan, and I made him trash his car. He was so intent on beating my that he took a risk he should not have.
http://forums.maxima.org/showthread....5&pagenumber=1
Just the other day, I TL-S blasted by me. I was like OK, let me join in the fun. I chase him down. Rather than race him, I stick to his tail, he downshifts and jumps ahead a half a car lentgh, I'm in 3rd and accelerate. The car length slowly gets bigger, but traffic slows him down, we do it again, he pulls slowly. I'm thinking, I should be with this guy, but then I realized, I had a passenger, he did not. Anyway, not really a race but some good fun.
DW
DW
He doesn't have a TL-S. He's a poser that drives a Cavalier while his mom drives a TL-P. The reason he always ask us to race him is because hardly anyone here is located in Denver, so he thinks no one will race him in his Cavalier.
OK well when people talk **** about there cars i think they should have pics to back it up just my 2 1/2 cents
What is so hard to believe that I have a TL-S? I don't have to show any of you any pics.
Actually I love the 2K2 Maxima SE. It is a better overall value than the TL-S. I almost bought one, but I decided to lease a TL-S because the residual is thousands better and the interior and seats are better too. When my lease is up I can by the car and then sell it the next day and make an easy $1000 - $2500 or so too.
I think there are a bunch of liars out there that like to tell stories like children. I also have a 91 Stealth RT/TT. I will CRUSH any of your 2K2 SE's in that. I have already walked Maximas by over 8 cars lengths to 80mph from a dead stop. If any of you has the ***** come meet me in Denver. I am an Engineer at Time Warner Telecom. PM or e-mail me. I'll step up and race anyone here. I'll bring the TL-S AND my Stealth. Also ask Jeff Lucius (that is also his user name at 3SI) over at 3SI. He knows me personally and has seen both of my cars and knows exactly who I am.
Originally posted by dwapenyi
Remember we live in a country where sudden acceleration almost put audi out of business. 5 years after, the government finally admitts it was stupid drivers.
DW
DW
Oh really....
actually who gives a damn who you are, what you do, what you drive, or who your 'friends' are...
I mean sh#t!!! Grow the hell up...going around to forums and then calling people pussies! Crap, and you have the nerve to insinuate that Max owners here are "like children"...grow up JUNIOR!!!
You need some major psychological analysis to deal with your need to throw a tantrum and act like an ***.
Thanks guys this was a very interesting conversation until MB-Telecom stated talking about PUSSIES ("That show the Level of his Intelligents"). But in all I enjoyed this very much. I do not dislike TL-S or CL-S but a race is a race and a win is a win.
Keep pushing to the limits but do it safe.
Nice
Nice
why you ask because you come in here ranting and raving on i can do this and that and you would have to be running 20 psi to pull 8 cars on any max
BTW, I took out a CL-S yesterday with my fiancee's 4th generation Maxima (note: 190 hp). The loser got ticked off and drove in the turning lane to catch up to me (because he couldn't keep up and got stuck behind traffic).
yongjun
Feb 24, 2002 11:34 AM
