2k2 shift knob
Old Jun 4, 2002 | 06:36 AM
dblrr900's Avatar
2k2 shift ****
I hate starting threads but I gotta know...
Does anyone else hate the shift **** on the 2k2 6spd? I like the look but mine turns all the time, every time I shift hard it twists loose and I flip out. I want to change it out for something like the Big Momo, but I don't want to interfere with the "Reverse lift lever". Anyone else install something that actually works? Preferably something that screws on.
Old Jun 4, 2002 | 06:39 AM
Hobert's Avatar
Re: 2k2 shift ****
I've had no problems with mine coming loose while shifting. I think it looks decent and has a good feel.
Old Jun 4, 2002 | 06:51 AM
dblrr900's Avatar
well I was looking on Ebay for some shifters and look what I found:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1737020150
Just for those that have the need. Amazing what people will sell on ebay.
Old Jun 4, 2002 | 07:30 AM
THEKNITE's Avatar
Re: 2k2 shift ****
Where can i find a side view pic of the 2k2 ****. I'm interested in a leather one with some aluminum. If it's short, and if it will fit my 2k1, i'd trade with ya. I have a Momo, and the pic is on my page.
peace
Old Jun 4, 2002 | 07:48 AM
dblrr900's Avatar
Re: Re: 2k2 shift ****
peace
Is your **** round or oblong? I am looking for one like the GTI shifter. The big round one with the lether on top and metal on bottom. Does anyone know if the threads on the Honda stick and on the Max stick are the same? I found a sweet Titanium 6spd **** for a NSX, just need to see if it will even fit. It is a screw on too.
Old Jun 4, 2002 | 07:51 AM
THEKNITE's Avatar
Re: Re: Re: 2k2 shift ****
I dont' know, but mine is kind of round, and the piece with the screws on the bottom where you tighten the momo **** is metal.
Old Jun 4, 2002 | 08:50 AM
dblrr900's Avatar
Here is what I want to put on. Hopefully it will fit. I took my **** off and tried to put it onto a civc shifter. It started to work, but the honda pot gets wider as you go, where as ours stays the same width, I am thinking it will work. Hoping so.
Old Jun 4, 2002 | 09:40 AM
WILLSE's Avatar
FYI the shift **** is straight out of a skyline gt-r! mine moves if i want it to but its not so loose that it distracts me! i think it works fine! go to nissan and see if they can tighten it up!
will
Old Jun 4, 2002 | 09:46 AM
DrVolkl's Avatar
peace
Wouldn't bother you that it has the gate pattern for the 6-spd on the alumiplastic center stripe on the ****?
I like the thing...but my plastic thing moves when I shift. I hate that.
Old Jun 4, 2002 | 09:58 AM
dblrr900's Avatar
well I am thinking about the JDM **** I have shown. I am going to pick it up and if it works great, if not, then I will sell it to some shop around here. There are a ton of Honda guys here that would put that on there car even though they don't have the 6spd. Or even for the RSX guys.
Old Jun 4, 2002 | 10:50 AM
Stereodude's Avatar
Mine is loose and it ticks me off. You can change the **** without any problems though. Just unthread it off the top. It's simple. I'm going to try putting some Lock-tite on the thread for mine and see if that helps any. I've taken it apart (as much as I could) and I don't really think that there's anyway for the dealer to "fix" it unless they have something like Lock-tite, or they can glue it in position. The inside where the threads are does not rotate inside the ****.
Stereodude
Old Jun 4, 2002 | 10:58 AM
condor9382's Avatar
Threading holes
Just to let you know... if you want that shift **** to fit your civic. Just figure out the size of hole and the thread percentage that you want and take it to any local machine shop. They can drill and tap a new hole in that shift **** for you. I work for a company that sells tapping arms and that's what we specialize in. You could even send it to me and I'd tap it for free. www.flexarminc.com
P.S. If you can remove the shifter off the Honda you can always "turn down" the shank of shifter and then externally tap the shifter to fit the shift ****.
Old Jun 4, 2002 | 11:05 AM
dblrr900's Avatar
Stereodude - yeah I know that you just have to unscrew it, that is why I would like another unit that can screw right on, so I dont have to mess with the sink screws and adapters from other kinds.
Condor - no, I am trying to put that peice in the picture on my Max. It is made for/and fits Hondas. It looks like the Honda Shifter is the same size at the initial thread but gets larger as it comes down.
I am not trying to make this a huge project. I just want something that is simple and stable to put into my hand. I like the stock unit, but it sucks, it is made from plastic and doesnt stay tight. I wish they would some out with a real shift ****. Maybe with the NISMO stuff they will, but I doubt it.
Old Jun 4, 2002 | 12:09 PM
condor9382's Avatar
[QUOTE]Originally posted by dblrr900
[/QUOTE
Still if that honda **** doesn't fit on your max... You can (or anyone can) easily machine (drill and tap) the hole to fit your maxima shifter. All you'd need to do is measure the max shifter and drill and tap the shift **** to that size. Because I have every conceivable piece of equipment to drill and tap, it would be very easy for me to do. Easy for any machine shop to do very quickly (like 5 mins), probably for free. SO, hopefully you can just make it fit w/out this. However, if it doesn't don't give up on your idea, just get this thing tapped to the correct size. Good luck! Nice looking shift **** btw!
Old Jun 4, 2002 | 12:38 PM
Colonel's Avatar
Old Fuddy Duddy
Originally posted by Stereodude
Mine is loose and it ticks me off. ...The inside where the threads are does not rotate inside the ****.
Stereodude
I know this sounds stupid...but on my Probe the handle was loose as everyone is describing. I took a strip or two of duct tape around all the threads and then rethreaded the ****. Worked like a champ and nothing messy to deal with. I thought about thread lock but did not want to risk making a goopy mess as I am a clutz.
BTW I tried electrical tape first but in the heat it got to gooey and sliped and started to twist again.
Old Jun 4, 2002 | 01:50 PM
dblrr900's Avatar
Good call. Duct tape comes through again. Best invention ever!
Old Jun 4, 2002 | 02:19 PM
Y2K2Driver's Avatar
I did kind of the same thing, but instead used plumbers teflon tape which is specifically used for threads. Since it is very thin, it is easy to adjust how tight the shift **** will be.
Old Jun 4, 2002 | 02:24 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: 2k2 shift ****
Stick with the oem shifter.
Old Jun 4, 2002 | 02:41 PM
dblrr900's Avatar
I am in the process of picking that one up right now. I am switching over man, hold me back! IMO the round one is easier to deal with, the grip is the same no matter how you grab or shift. Plus it is pretty snazzy
Old Jun 4, 2002 | 03:39 PM
burgerking's Avatar
great find man! just what i was looking for! j/k. lol.
Old Jun 5, 2002 | 09:43 AM
dblrr900's Avatar
So I tightened the **** down real tight, I mean I ranked on it. I turned it prolly 1 or 2 more times than it was when I got it. It is nice and solid now. I may stick with the stock one, but I think that Titanium shifter would look real good on there Only thing is that Titanium will run me about $70 to get.
Old Jun 5, 2002 | 10:44 AM
chinaonnitrous1's Avatar
that was a good price...
Old Jun 5, 2002 | 11:07 AM
Jet
Dude,
My shift **** was loose as well. During hard shifting the **** would spin in my hand and mess me all up. I just forced it around one more revolution and the thing has not moved ever since. It was a little difficult to do but not that bad.
Jet
Old Jun 5, 2002 | 11:14 AM
Ive got a skyline GTR shiftknob sitting here...its like hte 2k2..but the middle plastic peice is metal (titanium color) its engraved with the 6 speed shift pattern..and has GTR engraved on the back colored in....but..its too big...it kinda just slides on....barely gripping the threads...will plumbers tape work?..I was thinkinng of a heli-coil to shim the gap..but i wouldnt know how to begin...or who to talk to..
Old Jun 5, 2002 | 11:35 AM
THEKNITE's Avatar
Probe
That's funny, I also had the Probe GT before the Max. The oem leather **** just started to peel as it had 125k miles, so I had to change it.
Old Jun 5, 2002 | 12:24 PM
dblrr900's Avatar
That is sweet that you have one. I would use some duct tape or something. Get that thing on there!
Worste case take it to a machine shop.
Old Jun 5, 2002 | 10:04 PM
Triple8Sol's Avatar
I miss the .org!
I didn't really see this issue addressed yet in this thread. When you change the shift ****, how does that affect the "reverse lift lever." Is it a separate piece from the shift ****, and will stay on the thread when you change the ****?
Old Jun 5, 2002 | 11:40 PM
ABS's Avatar
ABS
Re: 2k2 shift ****
I had this problem with mine too. Just give it one full turn clockwise, to tighten, and your problem will be solved!
Old Jun 6, 2002 | 05:31 AM
condor9382's Avatar
Helicoils...
I deal with helicoils. That may be a very good solution. Find a way to measure the stick and the hole in the ****. You might be able to just use any regular insert from a hardware store.
Old Jun 6, 2002 | 05:49 AM
dblrr900's Avatar
Yes the lift lever is separate from the ****. The **** will turn and the lever (a little round disc that you pull up with two fingers to go into Rev.) will stay on. The issue is there is not a lot of room on top of the shifter like most sticks, due to the lever being there. To make it more difficult you cannot install a **** that goes onto the stick too far as well because the lever has to be able to lift up & down to operate.
TallTom
57
Oct 14, 2025 05:16 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
