A favor to ask
Old Jun 6, 2002 | 04:45 PM
Young04's Avatar
A favor to ask
Hello everyone. i am hoping that someone with a little more mechanical knowledge can help me out with this one...basically, my car (2002 GLE) is making a whining noise under throttle (in park and in drive) and someone told me that something may be wrong with the throttle body. my question is, what is a throttle body, where is it, and how do i check if there is something wrong with it? is it something that i can know by visually inspecting it? thanx for any advice you guys can give. cheers.
~young
Old Jun 6, 2002 | 04:51 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i cant say i have ever heard a throttle body whine, but its easy to fine. if you find your airbox where the air filter sits, follow the hose which runs up and to the left if you are looking at it straight on. you will see a small black box which is the stock resonator. go another foot or so and you will see where the black hose ends and is clamped on to a piece of metal on the engine. if you loosen the clamp, look inside towards the engine and thats the throttle body. if you find the throttle cable, you can push on it and the throttle body will open manually. just do this with the car off otherwise it will stall. as far as the whining, just make sure that its connected and covered by the hose properly and that the throttle body opens up all the way.
Old Jun 6, 2002 | 04:53 PM
Young04's Avatar
ok, thanx, i'll give this a shot tomorrow.
Old Jun 6, 2002 | 06:31 PM
02maxima's Avatar
do you have a custom intake . it may be the hose that connects to the valve cover . had the some problem when i put my intake in my car
Old Jun 6, 2002 | 06:34 PM
02maxima's Avatar
2002 maxima does not have a throttle cable
Old Jun 6, 2002 | 07:55 PM
Green_2's Avatar
The only whining noice that I've heard so far is the alternator going bad. If the throttle body is not the problem, you might want to look at the alternator.
Old Jun 6, 2002 | 08:03 PM
dblrr900's Avatar
2002 = take it to the dealer. If there is something whining.... it is not good. I would autpomatically look at pulleys and belts, something needs adjustment.
Old Jun 6, 2002 | 09:07 PM
WILLSE's Avatar
this is normal man! mine whines very loud ESPECIALLY when i first crank it up! it almost sounds like a supercharger!
will
Old Jun 7, 2002 | 03:10 AM
Young04's Avatar
my car is completely stock...the noise seems to be coming from the left of the engine bay, where all of the belts are...
Old Jun 7, 2002 | 06:35 AM
NYC2SD's Avatar
You should be dealer bound. Whatever it is, it'll be under warranty. For 2K2 the throttle is all computerized, so its hard to mess with yourself.
Old Jun 7, 2002 | 09:00 AM
sloppymax's Avatar
thats my bad, i forgot about the electronic throttle control. if its coming from around the belts, i would advise taking it back in. could be a defective pulley or belt.
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
Maximus44
Jan 16, 2002 05:15 PM
Stereodude
Jan 15, 2002 06:05 PM
WoodEar
Sep 1, 2000 11:25 AM
