Stillen X drilled Brake Problem
I installed stillen x drilled rotors and pads today. Look very good but, they don't sound good. U can hear them rubbing a little when u go slow. Not horrible rub but a liitle. Does anybody have any ideas of whats wrong or how to fix? Would aprciate the help. Thanks
the noise is normal for a few hundred miles since you're breaking in new pads and rotors. It should mostly disappear after 300-500 miles. Most semi-metallic pads make slightly more noise than the stock organic pads (but only if you turn music off and have the windows down will you notice it)
