Going to Track on Friday a Few ????
Old Jun 16, 2002 | 10:21 PM
CIRCO's Avatar
I am going to run the 1/4 mile on Friday of this weekand have a few questions. I need to run 14's or I am going to be ****ed! I have a stillen Y, full hayame catback, franken/JWT hybrid for performance mods.
1. Should I put the stock rims on the rear? If so what PSI should I have them at?
2. Should I remove spare, and sub?
3. What RPM's do you think is the optimal launch rpm? For example, least amount of wheel spin and minimal lag for low rpms.
4. At what RPM do you m/t guys shift from 1st, 2nd? I have hit the rev limiter in 1st at like just a tad past 6500rpms and think right before the limiter should be the shift point.
Any help is appreciated. This will be the 1st time I am taking the max to the tracks, but I have taken my civic, GSXR, and CBR back in HS.
Old Jun 16, 2002 | 10:27 PM
KLOOGY's Avatar
L33t BMW Drivah
Just run as is. When a TL-S pulls up next to you on the street, are you going to stop, and take your spare and subs out ? You should want to know what your car performes like as is ...
Old Jun 16, 2002 | 10:29 PM
MAX2000JP's Avatar
Re: Going to Track on Friday a Few ????
No
Yes, the less weight the better. Take the spare,jack,and sub out and leave them home. Also, try to go to the track with about 1/4 tank. The less weight the better your chances of running 14's
I found that launching at 3250 and slipping the clutch very slightly netted me my best 60' times. Lower your front tire pressure to around 27 and the rears to about 40 also.
Shift at redline(~6600 rpms) in every gear. Thats where your peak hp is.
Old Jun 16, 2002 | 10:34 PM
CIRCO's Avatar
Re: Re: Going to Track on Friday a Few ????
No
The rev limiter kicks in at like a little past 6500rpms man! Redline is 7000rpm! At least thats what I have experienced in 1st and 2nd gear.
Old Jun 16, 2002 | 10:36 PM
MAX2000JP's Avatar
Re: Re: Re: Going to Track on Friday a Few ????
Redline is 6600 rpms...it will fuel cut anything after. 7000 rpms cannot be achieved with an upshift, unless the tach is off or they come out with a chip.
Old Jun 16, 2002 | 10:39 PM
CIRCO's Avatar
I take down Cl-S's daily! This is for my best time possible, not to prove I can smoke a car that I already beat on numerous occations. BTW, my good friend has a CL-S, but its a 2001 not the 2003. Funny that you said this though LOL, you have the 3.5L I only have the 3.0L every little ounce counts man. BTW, you interested in the 2 rims?
Old Jun 16, 2002 | 10:52 PM
KLOOGY's Avatar
L33t BMW Drivah
Yeah, email me. I like those and the Neeper Haaz. I would chrome yours though..... Im just concerned with shipping charges to the mainland....
Old Jun 16, 2002 | 11:00 PM
CIRCO's Avatar
Neepers are big dollas dollas! Plus they weigh a ton! But they would turn some heads
Old Jun 16, 2002 | 11:02 PM
KLOOGY's Avatar
L33t BMW Drivah
Im figuring with my upcoming mods, I can handle the extra weight. I actually have an offer for DUBS for 1600 w/ Tires that would look insane, but I still need to race. The Neeper 18's arent much heeavier than my stock BRICKS !
Old Jun 16, 2002 | 11:03 PM
CIRCO's Avatar
With tires they will be a lot heavier than your stocks! But who cares you have a 3.5L nothing can slow that down.
Old Jun 16, 2002 | 11:05 PM
KLOOGY's Avatar
L33t BMW Drivah
Yeah, my Auto Tranny !.... .... Thats ok, its what I wanted...
Old Jun 17, 2002 | 02:22 AM
2K1HoMax
Re: Re: Re: Re: Going to Track on Friday a Few ????
i was able to take an auto max (no not mine) up to 7500rpm before the fuel cut off! i was goin pretty dam close to 100mph in second, but im not sayin go that high.
Old Jun 17, 2002 | 07:54 AM
xChungHsienx's Avatar
Re: Re: Re: Re: Re: Going to Track on Friday a Few ????
Tire pressure that worked for me at the track was 25 or a little less in the front and 40s in the back. Dropped couple tenths just by changing pressure.
Chung-Hsien
Old Jun 17, 2002 | 08:03 AM
MAX2000JP's Avatar
Your tach is off. The computer will fuel cut after 6600 rpms.
Old Jun 17, 2002 | 08:39 AM
craaaazzy's Avatar
Re: Re: Re: Re: Re: Re: Going to Track on Friday a Few ????
i have to agree w/ that...no way can u go 7.5k.
anyways, play w/ ur tire pressure. i would run anywhere between 23-26 psi for the fronts, pump the back to the max amount allowed for ur tire. take spare, jack, sub out. go all the way to red or 6500 if ur uncomfortable about ur shifts since u have a 2k. if u want the best possible time, i would put ur stock rims up front but not worry about the back. since u got dark tints like me, u could take out ur back seat and nobody would know. my best launch so far has been if i rev up to 3k and then slip the clutch a little. need to know play w/ that but i've heard others going a bit higher and getting a better 60' time. depends on how much u want to punish ur clutch though.
Old Jun 17, 2002 | 12:49 PM
CIRCO's Avatar
Re: Re: Re: Re: Re: Re: Re: Going to Track on Friday a Few ????
Stock rims up front would reduce my traction for the launch. However, changing rear tires to stock would reduce drag that the high performance tires create, plus weight reduction for going to 15" steelies. BTW, I can punish my clutch as much as I want I have a replacement clutch and will be replacing it with a flywheel by next month.
Old Jun 17, 2002 | 01:35 PM
craaaazzy's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Going to Track on Friday a Few ????
my bad. how wide are the tires for the 15" rims? i would use those for the front if they're comperable tire widths. and if u don't care about those tires that much, u could probably drop pressure to 20 or so. as for the replacement clutch, i would go ahead and start launching from 3000, then move up 250 rpms each other runs and see how ur 60' times decreases/increases. slipping it more would give u the best launch also. keep us informed on ur findings...i also need to improve my launch. good luck and have fun!
Old Jun 17, 2002 | 01:40 PM
CIRCO's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Going to Track on Friday a Few ????
The steelies 15" are stock 2K GXE rims they have like 205/60or65/15's on them I think so switching up front wouldn't do me any good. Launching from 3K is what I have been doing while slipping clutch so thanks for the suggestion of moving up 250 rpms every run after I will try to see at which rpm I have least amount of wheel spin. With my mods do you think its possible to be in the 14's man?
Old Jun 17, 2002 | 03:26 PM
ZIPPIN's Avatar
Mauja He Mauja
Old Jun 21, 2002 | 12:26 PM
CIRCO's Avatar
So whats the verdict guys?
I am going tonight! Here are the conclusions I have come up with using your input let me know what you' all think:
1. Don't change out tires.
2. Do change pressure 27front 40 rear
3. Take out sub, spare, jack, and possibly rear seat
4. Launch in first a 3500rpms slipping clutch
5. Shift points all at 6500 or a little past right before limiter
I have a few more questions:
1. At 3500rpms the tires still spin a little, so does that mean I should lower rpms to reduce burn out/ loss time.
2. Should I keep my gas at a minimum? I have the gas light on now? I don't want to run out of gas on the 1/4?
3. What time should I expect?
4. How heavy are stockers? GXE 15" steelies with hubcaps
Old Jun 21, 2002 | 12:56 PM
craaaazzy's Avatar
i would lower pressure up front. gives u better grip. try 27 first like u want, if u still lack traction, reduce to 25, then 23 if necessary. slip clutch a little more to reduce spin...
good luck!
Old Jun 21, 2002 | 01:13 PM
CIRCO's Avatar
good luck!
Thanks but aren't the Moda's hella heavy?
Old Jun 21, 2002 | 04:28 PM
CIRCO's Avatar
HELP GUYS help!
still have a few questions to answer could you guy help me out before I go to the track!
Old Jun 21, 2002 | 06:34 PM
woosh's Avatar
1. Yup 3500rpms might be a little too heavy. I'd launch around 3200 rpm, 3/4 sink on pedal til about 4000 then WOT. should minimize your wheel spin(practice, practice). Depending on your shifting speed, I'd shift around 6300, remember this is your every day baby.
2. 1/4 to 1/2 tank is good
3. Time? Alot of it is the launch, shifting speed/accuracy and how hard you are willing to work your clutch.
4. Don't know how heavy the steelie 15" are but I'd suspect lighter than 50 (stock SE 17"). I don't think the back seat is a quick and easy removal.
Old Jun 22, 2002 | 08:35 AM
VQdriver's Avatar
for the best possible time: like people have suggested, put your stock fronts back on. i've lowered my fronts to 15.5psi. works for me. remove everything in your car you don't need. empty out the glove and console (this is the perfect time to clean your car). remove front and rear seats. it only takes about 10 mins. run with about 1/4 tank or less. remove the jack and spare when you get to the track. i like to hold my rpms at around 1,500rpms and watch the tree. with the lowend torque we get, high rpm launches will result in spinning tires unless you feather the clutch which i do not like to do. i take the low rpm launch method because it is very easy. when the third yellow lights, "mix" the clutch and throttle rapidly, but don't "drop" the clutch. you should not bog if done properly. chirping the tires slightly i routinely get 2.1-2.2 60's that way plus i concentrate on the light. between 1st and 2nd i shift at redline. from 2nd to 3rd i shift at 6,200rpm, but since you have a 2k try to go for the redline since you have more top end. i don't shift into 4th because the 1/4mi ends at the top of my 3rd gear.
Old Jun 22, 2002 | 08:42 AM
VQdriver's Avatar
good luck!
your steelies weigh apx 42lbs with the tire. that's probably lighter than your aftermarket rims/tires. i'd go with stock fronts. i have concluded that any attempt to keep tire pressures above 16psi have resulted in higher 60' times. at first i was very cautious until i found out all the light and heavy honda and mustang/camaro drivers alike all lowered their psi to 15. i'd stay with 15.5-16.5psi. it will vary at the track depending on air temperature, so keep it low especially when it's warm outside!
Old Jun 22, 2002 | 11:50 AM
dino1063's Avatar
Re: HELP GUYS help!
So how did you do?! What all helped you the most?!
Old Jun 22, 2002 | 01:47 PM
CIRCO's Avatar
Re: Re: HELP GUYS help!
Uh look at my 1/4 mile post. What helped me the most. Hmmm I never took my spare, sub, or jack out. I pumped up my tires in the rear to 40 and ran it with the modas on. Because the track was wet it was impossible to lauch with out spinning first entirely. So I guess you could say it was just a learning experience.
Old Jun 23, 2002 | 02:27 PM
F23A4's Avatar
Re: Re: Re: HELP GUYS help!
The track was wet?? And you guys still ran?? WOW!! At Etown, one drop of rain shuts the track down for about an hour; then some dude in a maintenance truck drives ten feet down the track, gets out, stutter steps (in his sneakers) across the track for about two minutes, gets back in the truck, drives another ten feet and does it again AND this goes on until he covers the entire 1/4 mile AND deceleration lanes.
Old Jun 23, 2002 | 02:34 PM
2K1HoMax
Re: Re: Re: Re: HELP GUYS help!
thats why it was stated earlier on in this therad that hawaii's track is a joke.(no offense) but damn uve been to the track one too many times it looks like. but yeah thats what they usually do, dont want to risk any1 loosing traction of a 1000+hp car at high speed.
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
jonreidhead
Jan 6, 2016 09:38 AM
