KYB AGX 5th Generation- over a year away
This is from an e-mail from KYB tech support.
"Catalog will be out in March 2003 but product probably will not be available until Late Summer 2003".
I was relatively optimistic when I heard that they would be available in the 2K3 catalog, but the product won't be available until late summer!!!
I am going to have to buy the damn Tokicos because you can't have the modified 4th gen AGX's with Eibach. Arrrrggghh!
Originally posted by Greg's2kGLE
Weren't they supposed to be out this summer? Isn't Tokico coming out with adjustable struts soon?
Re: KYB AGX 5th Generation- over a year away
Re: Re: KYB AGX 5th Generation- over a year away
Originally posted by Deven2kStickMax
i have noticed on here that Progress and H & R springs work well with the modded AGX. I had problems using my Eibachs on AGX, but i'm having ideas about getting the correct springs for it. I sold my AGX, but i don't mind buying it again to use Progress or H & R with AGX. Also i think you can keep your front eibach and buy the 4th gen rear eibach to work with the AGX...i kno the damnn 5th gen one is 1 yr away ...that's so long....i gotta do something to my car soon. i hate my tokicos i have on now, they are too soft ...
BTW- I can't send you a PM because I
In March/April this year I had been in contact with Tokico about 5th gen Illuminas. They told me they were almost done, but they meant for 4th gens. 5th gens could be late this year.
Re: Re: Re: KYB AGX 5th Generation- over a year away
I am really confused right now. Tokicos are soft? Like they soften the ride? Do they bottom out? I need struts all the way around. I have Eibachs. I would rather not have to modify anything. What should I get? I don't mind a "soft" ride because the Ground Controls are harsh as hell.
Originally posted by Mystical2k2SE
The Maxima gets snubbed once again.
I betcha the Altima (and that other new car from Nissan who's name cannot be mentioned on this board per the moderator) will get this stuff before the so-called "flagship" car does.
what are you talking about?
"Thanx for the offer, but I am afraid we cannot accomodate this. There is no way to expedite development and release of these designs. They are scheduled already. Also, KYB does not accept group purchases."
I'm going to a suspension shop today. Hopefully they will have some ideas for me.....
I offered to put together a group buy of 10 units if they can speed things up a bit and this was the response...
I have rear 4th gen AGX's with Eibach and have no problems, no noise, no vibration, no nothing. The spring perch OD is not optimized to allow the Eibach spring to sit ideally, but both springs sit in the same location and no matter the bump or pothole I have not have any issues whatsoever. Got Tokico Blues up front...better than stock by far. I just adjusted the rears to match the front rate by road feel and I'm a very, very happy camper.
Originally posted by srbarnes4ever
That does suck poop, shows how much some of these suspension companies feel about our Max being a performance vehicle...
Did you have to modify the rears at all?
Re: Re: Re: Re: KYB AGX 5th Generation- over a year away
Not one ounce my friend....I'm perplexed as to why you'd need to. I just removed the original Toks, compressed the spring to remove the upper perch, pull the crap off, put the still compressed spring onto the AGX and put the dust boot, bumpstop, upper perch on and tighten nut then reinstall. Set to 3 and I'm rollin like a ****! Not a peep out of them...of course the front Toks were a direct replacement too.
03-12-2020 12:06 AM
dvcamp
09-18-2015 10:17 AM
Violator
09-09-2015 10:14 AM
