Painting hoses and Injen
Old Jul 1, 2002 | 03:32 PM
MichaelAE's Avatar
Believe it or not, I have had a hell of a time finding anyplace which sells the straight silicone hoses (~3") or even the breather tubing in BLUE. Places like Hosetechniques don't sell the larger diameter tubing except in RED and BLACK. BLUE is my chosen car color, so...you understand the awesome amount of frustration I must be experiencing.
So I resorted to painting the hoses that come with the Injen CAI (came all in RED) with spraypaint. After an extensive research project, which lasted at least 5 minutes, I chose the Dupli-Color High Heat w/Ceramic spray paint in Flat Blue (DH1612). Chosen for its ability to bond to almost anything and resistance to temperatures up to 1,200F degrees. After a couple of troublesome sprayings, I've finally managed to get these things painted.
For anybody interested, the stuff dries really fast, but if you don't let it cure in some heat (either oven of direct sun) it will come off like dried glue after it comes in contact with something warm (like your fingers). Sitting the tubes on a pizza pan for a little bit in your oven at around 200 degrees does the job pretty well. I'm sure your engine bay would accomplish the same thing, but I happen to need the paint cured to get the hoses in the engine bay in the first place.
Anyway, it came out looking pretty good. I haven't installed the intake yet, but I'll let you know. I even painted the filter base (skipped the cap since it won't be visible). I wrapped the element in tape, covered the opening with an old CD (hole in the middle taped) and sprayed it BLUE. Looks good. FYI...don't do the oven thing with the filter...that would be bad.
So, for anybody who just can't stand red and wants an Injen CAI, feel free to try my solution...it would appear to work.
Old Jul 1, 2002 | 03:56 PM
jconway's Avatar
wealth of knowledge
Where and how do you figure this stuff out? Can you write a book on all the cool ****e you can do to a maxima, I'd buy it in a second.
-jc
Old Jul 1, 2002 | 03:57 PM
MichaelAE's Avatar
Re: wealth of knowledge
-jc
While I appreciate that...trust me, there are many other members whose books would be a far better investment.
Old Jul 1, 2002 | 06:06 PM
mdeal's Avatar
Will the paint eat the hose? DupliColor is known to be more "hot".
Old Jul 1, 2002 | 06:07 PM
Maximum Velocity's Avatar
GReddy actually has the blue hoses in larger diameters. If you could, can you measure the diameter of the hoses in millimeters and also measure the lengths of the hoses please. Then I'll see if GReddy carries the right sizes.
Old Jul 1, 2002 | 06:11 PM
NYC2SD's Avatar
I don't want to sound like a broken record but..post pics when you can!
Old Jul 1, 2002 | 06:26 PM
soundmike's Avatar
Very sound, Mike
Hey Michael, glad to see you've finally done it Post up some pics!
Old Jul 1, 2002 | 06:32 PM
MichaelAE's Avatar
15mm vacuum line for breather tube
2.75" straight tube
3.00" straight tube
3.25" straight tube
Old Jul 1, 2002 | 06:38 PM
MichaelAE's Avatar
Hmmmmmm. I won't answer that because I haven't really done enough reading to know for sure. I would hope that the ceramic inclusive paint would harden a bit preventing that. I could be crazy though. If Greddy has the hoses I want, I'm buying them though. I would rather not have the painted hoses.
Old Jul 2, 2002 | 05:25 AM
2.75" straight tube
3.00" straight tube
3.25" straight tube
Okay, I think that the 15mm is going to be a little hard to come by, but the measurements in inches are the diameters right? I'm assuming that the tubing also has a universal std length of about 3".
Old Jul 2, 2002 | 08:33 AM
MichaelAE's Avatar
Well the 15mm is the one that serves as the breather line on our stock air filter. On the length, the larger straight hoses I need in 2" lengths (but I'll buy the standard length and cut it). The smaller 15mm tube I need 16" of.
Old Jul 2, 2002 | 03:18 PM
yongjun's Avatar
OoOoo
I was wondering where i could get some blue hoses for my breather filter line.
Thanks so much for the info.
Old Jul 2, 2002 | 03:45 PM
MichaelAE's Avatar
Photograph of BLUE Injen parts
Old Jul 2, 2002 | 04:25 PM
MAX2000JP's Avatar
My friend did this on his 66 Mustang with the same high temp paint as you used and his started to flake off after a while.
Old Jul 2, 2002 | 04:26 PM
MichaelAE's Avatar
I, actually, have since coated it with a laquer which I'm hoping protect against that. We'll see. I'm still looking for a retailer who will sell me the 15mm breather line in blue and the straight hoses.
Old Jul 2, 2002 | 04:30 PM
Jeff92se's Avatar
I'm needing a caw
http://www.bakerprecision.com/purosil.htm
Old Jul 2, 2002 | 04:56 PM
MichaelAE's Avatar
Believe it or not, I found that. Of course, they don't sell the 3.25" straight hose!!!! Or the 15mm breather line! GRRRRR!
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
