In The Market for new Rims, Need a little help
Hi Guys,
Im in the market for new 17 inch lightweight rims. I referenced the weight chart and searched through a few websites, and here is the best I found:
http://www.wHalentire.com/wheeldetai...10H40S&size=17
http://www.tirerack.com/wheels/Displ...atin+Sil+Paint
Weight 16.5
http://www.tirerack.com/wheels/Displ...Silver+Painted
weight 17.0
do you know of any other wheels with equal or lesser weight?
Thanks for any help!
Weight 16.5
weight 17.0
Re: In The Market for new Rims, Need a little help
Originally posted by stose95
Hi Guys,
Hi Guys,
Re: Re: In The Market for new Rims, Need a little help
Originally posted by y2kse
I don't care which 17" wheel you purchase, stose95. Just make sure it's at least 7.5" wide.
I was planning on keeping everything stock measurements. (17x7 w/ 225/50/17 tires)
Re: Re: Re: In The Market for new Rims, Need a little help
Hmmm, How come?
Hmmm, How come?
Re: Re: Re: Re: In The Market for new Rims, Need a little help
Originally posted by Thorzdad
When you move from the stock 7" wheel to a 7.5" wheel, you open yourself up to a much wider selection of tires that will safely fit your car. There just aren't many choices of rubber at the stock size...and what ones there are are very expensive.
Triple8Sol i checked out those axis wheels, 4 spokes seems like they may be a little weak. Looks are not that appealing, but thanks for the reference anyway.
Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
I could probably go to a 245-45-17 size or so.
Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
That tire size would be an excellent choice on 7.5"-wide rims.
Re: Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
Originally posted by asu174
I have a 7.5" wide rim and according to Toyo, I should not go any wider than a 225 series.
http://www.toyo.com/tires/index_frame.html
Pay particular attention to the third column from the left with the title "Rim Width Range (inch)" at the top.
Once again, folks, don't take ANYONE's word for tire specs. ALWAYS get your specs from the manufacturers' web sites.
Re: Re: Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
Really, asu174? Did you get your information from the Toyo web site? If not, perhaps you ought to look there:
225/40ZR18 92W* 189880 7.5-8.0-9.0 21 9 25.0 9.1 11.8 1388 50 831
235/40ZR18 91W 189890 8.0-8.5-9.5 25 10 25.2 9.6 11.8 1356 44 823
245/40ZR18 93 189860 8.0-8.5-9.5 26 10 25.7 9.8 12.0 1433 44 809
Re: Re: Re: Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
Yes, this is what I see on their site
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
Originally posted by Maxima06071
Tire Rack must be full of crap . . .
My bad. I was confused. I thought you were referring to 17" rims, not 18" rims. Sorry about that!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
Now I'm REALLY confused. A 235 is a 235 is a 235- right? If you can't fit it on an 18" x 7.5, then how the hell can you fit it on a 17x 7.5???
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: In The Market for new Rims, Need a little help
235 is how wide the tread is, not the diameter of the tire. It could be a 10inch wheel and a 235 would still fit as long as the rim is wide enough to safely accommodate that desired size.
Let's see if we can make some sense out of all this. The confusion seems to be over aspect ratios. If you go to the T&RA Contour (Rim Width) tables on Page 5 of the FAQs, you'll see that the rim width ranges are the same for 17" tires and 18" tires provided the TIRE WIDTHS and the ASPECT RATIOS are the same. Thus a 235/45R17 tire and a 235/45R18 tire both have acceptable rim widths ranging from 7.5" to 9.0". Likewise, a 235/40R17 tire and a 235/40R18 tire both have acceptable rim widths ranging from 8.0" to 9.5".
Hope that helps.
Hope that helps.
Originally posted by cobymoby
You can fit a 235 on a 7.5 inch wheel, some manufactures reccomend it, some don't. I've done it many times.
Bryan- I wish you had told me that before I bought my stupid ghey 225 series...arggghh I guess it doesn't look too bad though.
Kosei K1 Racing Cast 15x7 13.5
Kosei K1 Racing Cast 16x7.5 15.5
Kosei K1 Racing Cast 17x7.5 16.7
http://www.tirerack.com/wheels/Displ...racite+Painted
Ahh..I love enlghtened and informed
discussions. To put this discussion in perspctive, there is an idiot in the parking lot outside who installed 245/60 Dayton (????) tires on a Buick Regal -with 6 inch rims. The tread is at least one inch outside the rim on each side...
Ignorance is bliss, eh?
Re: Ahh..I love enlghtened and informed
So, in conclusion, it is NOT acceptable to mount a 235 40 18 on a 7.5, but it IS acceptable to mount a 235 45 18. yes?
Re: Hey asu174...no not jojking, this guy has 16"
dimeter, 6" width rims running 245 tires.
I've been sorely tempted to leave hima note to see me....
galo
galo
Re: Re: Ahh..I love enlghtened and informed
Hi Guys,
Weight 16.5
weight 17.0
Hi Guys,
Weight 16.5
weight 17.0
Stereodude
