sway bar
Old Jul 5, 2002 | 05:10 PM
JJL's Avatar
JJL
sway bar
Well I received my sway bar today from cattman,installed it
Well all I can say is it is well worth it .
Really tightens up the ride
Old Jul 5, 2002 | 05:13 PM
[maxi-overdose]'s Avatar
Re: sway bar
it is....the best suspension mod at that price....have fun!
Old Jul 5, 2002 | 05:28 PM
paxus's Avatar
Re: sway bar
Eh, I searched these forums for Rear Sway Bar, and found out a lot of info, but very little description on what exactly it does for you? Not sure what is meant by "tightens up the ride". Does that mean you you feel potholes and bumps in the road more because the suspension is stiffer? Or does it have something to do with cornering? I would think the latter is true, but I'm not sure exactly what you experience once you install this RSB.
Old Jul 5, 2002 | 05:35 PM
Triple8Sol's Avatar
I miss the .org!
Try searching under RSB...somebody explained it in technical terms pretty well a lil while ago.
Old Jul 5, 2002 | 05:43 PM
Ludacris's Avatar
Is the Cattman GD still on?
Old Jul 5, 2002 | 08:57 PM
Y2KSESteve's Avatar
As of today yea it still is, but they are on back-order I think.
Old Jul 6, 2002 | 04:35 AM
JJL's Avatar
JJL
Re: Re: sway bar
Old Jul 6, 2002 | 04:39 AM
JJL's Avatar
JJL
Re: Re: sway bar
No it means that when you change lanes or corner
the body dose not roll as much giving the car a better feel.You still have a smooth ride it just handles a lot better
Old Jul 6, 2002 | 07:02 AM
MaxRU's Avatar
Re: sway bar
Same here
Quick questtion: ADDCO instructions say that it can be adjusted. Anyone knows anything about that?
Old Jul 6, 2002 | 08:34 AM
JJL's Avatar
JJL
Re: Re: sway bar
Originally posted by MaxRU
Same here
Yes it can be adjusted
The instuctions I got with it suck
Download the ones on this board
Old Jul 6, 2002 | 08:44 AM
BuddyWh
Re: Re: sway bar
Same here
For the greatest roll control, slide the outer bushings (and brackets) out to the ends of the bar and slide the inner bushings towards the bends in the bar. The right-side bushing may interfere with the link.
For lessend roll control slide the outer bushings backwards, toward the bends, and the inner bushings inwards, toward the center of the bar.
BuddyWh
Old Jul 6, 2002 | 09:06 AM
GimmeTorq's Avatar
Question
I have to get me a rear sway bar and it seems Addco and Stillen are the only alternatives. I like the Stillen but it is $$$. The Addco hardware does not look as good as the Stillen. The Stillen also looks like a cleaner design... I live in the Snow Belt and I don't want hardware that is going to rust after the first winter... How are your rsb's holding on??
Old Jul 6, 2002 | 10:04 AM
soundmike's Avatar
Very sound, Mike
Addco is zinc chromate plated... should handle pretty well against rust and stuff.
Old Jul 6, 2002 | 10:11 AM
Re: Re: sway bar
when u turn (esp on ramp, off ramp) with fast speed, u will notice that one side of the car "sinks" and once when the turns is over, "it pops back up" that's body roll and if u just doing one turn, it seems not that bad, but once you are doing an S-shape, the second turn is going to be hard to control.
it does stiff your rear suspension a bit but u still can have a nice ride on our crappy bay area high way.
Old Jul 6, 2002 | 12:04 PM
ms.thicknes's Avatar
Re: Re: sway bar
read to the bottom of this thread ...the thread was about fstb but it also answers questions about the rsb
http://forums.maxima.org/showthread....hreadid=131405
and these pics
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
