Installed Berk Intake But....
Old Jul 8, 2002 | 10:14 PM
kpark's Avatar
Two of the four screw holes on my MAF unit broke while trying to unscrew it from the stock air box. I ended up having to secure one half of the MAF unit to the aluminum adaptor using zip ties. Do you guys think this will do? I hope particles won't leak through. I also ended up drilling out two of the screws cause they ended up getting stripped. Damn Nissan screws those in tight and use the softest metal for their screws.
Old Jul 8, 2002 | 10:20 PM
[maxi-overdose]'s Avatar
Re: Installed Berk Intake But....
get replacement screws....u never know what happened to it if u are driving thru bumps. if it does leak thru, u will hear hissing sound and rough idle.
good luck.
Old Jul 8, 2002 | 10:47 PM
Maximam's Avatar
Get it done right! Just drill through and nut and bolt it if you have to. Zip ties will not do.
Old Jul 9, 2002 | 12:40 AM
cobymoby's Avatar
Sorry to hear about your installation woes! Here's how to fix it:
You should have plenty of leftover 10mm bolts that were used to secure the old stock air box to the chassis. Any of these will fit the supplied stainless steel nuts with the kit. Done deal. You now have a properly secured part.
Cheers,
Bryan
Old Jul 9, 2002 | 07:00 AM
Ghost face Max's Avatar
Re: Re: Installed Berk Intake But....
good luck.
DITTO, because anything could happen!!
Old Jul 9, 2002 | 08:50 AM
kpark's Avatar
Cheers,
Bryan
Thanks for all your suggestions. But I don't have any screw holes to screw anything into. The whole corner of the plastic MAF unit broke off on two ends. I'm gonna try to order a new part. I think it's the only way.
Old Jul 9, 2002 | 09:28 AM
MichaelAE's Avatar
For real? That, I think, is a new one. You probably want to contact DAVEB for a new MAF Unit, but they are expensive. Try to find out if you can get the housing without the actual MAF Sensor.
Old Jul 9, 2002 | 10:10 AM
kpark's Avatar
Dave just got back to me. It said Nissan services the MAF only as a whole assembly $390!!!! Damn. I'm screwed. I guess $390 is better than getting dirt inside my engine. Or maybe I can glue it together.
Old Jul 9, 2002 | 04:24 PM
cobymoby's Avatar
at $390 why don't you try buying a MAF from a junk yard. Try Nissan Only Wreckers, they're in Rancho Cordova, CA.
Old Jul 9, 2002 | 04:49 PM
kpark's Avatar
Thanks for the info. I'll keep this place handy. I was able to find a MAF unit from a place in Texas for about $100. Anyone know if I can actually use the sensor itself in place of mine? I'm just wondering if MAF sensors diff for CA specs or something.
Old Jul 9, 2002 | 05:07 PM
nope...once u replaced the MAF, u also have to re-program the ECU. so leave the sensor and change the unit.
Old Jul 9, 2002 | 07:18 PM
Foglght's Avatar
390......thats cheap. I paid 500 for mine. I guess i got ripped off. Yeah any holes of leaks in the MAF after the sensor, or even before will sound strange first of all, and greatly diminish performance. It may make the car feel like there is a dead spot in the pedal......or throw a check engine light and put the car in "limp" mode.
try some junk yards. The 2'nd time i had to replace mine it was only $135.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
