17-digit VIN decode
Old Jul 11, 2003 | 08:03 PM
ocuihs's Avatar
17-digit VIN decode
1N4 B A4 1 E 0 4 C 826008
above VIN number off Ebay at http://cgi.ebay.com/ebaymotors/ws/eB...tem=2422826674
I don't think this is a hail damaged car due to the serial number above 825000 as discussed in the forums.
First three digit (Manufacturer):
1N4 = USA car (1 = USA, N = Nissan, 4 = vehicle type or manufacturing division)
JN1 = Japan car
3N1 = Mexico car
JN6 = Japan truck
Fourth digit (Engine type)
B = KA24DE, SR20DE, VQ35DE
Fifth and sixth digit (model series)
A4 = Maxima A34
A3 = Maxima A33
Seventh digit (body type)
1 = 4-door sedan
8 = Xterra
Eigth digit (Miscellaneous)
E = ?
C = air bags
Ninth digit (check digit)
always 0 to 9 or X to verify VIN accuracy
Tenth digit (model year)
4 = 2004
3 = 2003
2 = 2002
1 = 2001
Y = 2000
X = 1999
Eleventh digit (Plant code)
C = Smyrna, Tenn
9 = Fujijyu
5 = Murayama
L = Aguascaliente, Mexico
M = Tochigi
Last six digit (Serial number)
FYI.....Check digit calculation (this is getting deep)
The Check Digit, position 9 in the VIN, is used by the factory and law enforcement agencies to verify that a particular VIN is a valid one for that vehicle. It is calculated by the following method:
1. Each number in the VIN is given its mathematical equivalent value.
2. Each letter in the VIN is given a mathematical value based on the following:
A - 1 ,B - 2, C - 3, D - 4, E - 5, F - 6, G - 7, H - 8,
J - 1, K - 2, L - 3, M - 4, N - 5, P - 7, R - 9, S - 2
T - 3, U - 4, V - 5, W - 6, X - 7, Y - 8, Z - 9
(I,O,Q = n/a)
3. The assigned value of each VIN character is then multiplied by the position weight factor as specified in the following:
Position Weight Factor
1st....8
2nd....7
3rd....6
4th....5
5th....4
6th....3
7th....2
8th....10
9th (ignored)...the above VIN check digit is 0 after calculation
10th...9
11th...8
12th...7
13th...6
14th...5
15th...4
16th...3
17th...2
4. The resulting products are then added, and that total is divided by 11. The numerical remainder is the check digit. If the remainder happens to be 10, X is used.
Old Jul 11, 2003 | 10:47 PM
gmc74's Avatar
I would guess that the E in the 8th digit is for side airbags/curtains, or something to that affect.
Old Jul 12, 2003 | 05:08 AM
ocuihs's Avatar
A = convertible; 3-point passive belts; driver/pass. SR & air bags, side air bags
C = air bags
D = air bags with 3-point belts
F = passive belt & air bag
H = heavy duty; w/ air bag
P = automatic/passive seat belts
S = no designation; 2-wheel drive; non-passive belt
T = 2-wheel drive, 4-wheel ABS
Y = 4-wheel drive, 4-wheel ABS
E = ??? (Research is still in progress.....)
Matt93SE
May 24, 2019 02:58 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
